[petsc-users] MSVC debug runs in a different branch.
Mon Jun 20 16:46:12 CDT 2011
On Mon, Jun 20, 2011 at 9:40 PM, Tian(ICT) <rongtian at ncic.ac.cn> wrote:
> Hi,
> Good morning/evening!
> I have this issue for quite a while. Using MSVC with Petsc, when debuging
> the code, the FormJacobian was never called, instead calling
> "MatMFFDComputeJacobian(SNES snes,Vec x,Mat *jac,Mat *B,MatStructure
> *flag,void *dummy)", though I donot use matrix free option.
> However, when runing the same thing in command line (still a debug
> compilation), I can see FormJacobian was called correctly.
> Any hint?
My guess is that you are getting the matrix-free option from somewhere
(maybe a .petscrc file?). You can use -options_dump to see
everything passed in. If not, look at SNESSetFromOptions() in the debugger,
and see why it is choosing MF.
   Matt
> Rong
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110620/53547d08/attachment-0001.htm>
