[petsc-users] MatSetValues and Zero enteries
Matthew Knepley
knepley at gmail.com
Mon Jun 20 16:34:05 CDT 2011
On Mon, Jun 20, 2011 at 9:31 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Thanks John -- taht's helpful. Do you also know how I can change the
> tolerance for dropping elements?
Right now, this only discards entires which are exactly floating point 0.0.
Matt
> Mohammad
> On Mon, Jun 20, 2011 at 1:12 PM, John Mousel <john.mousel at gmail.com>wrote:
>> See the matrix options available in the man pages. I think the function
>> below is what you are looking for.
>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatSetOption.html
>> MatSetOption <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatSetOption.html#MatSetOption>(A,MAT_IGNORE_ZERO_ENTRIES,PETSC_TRUE <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/PETSC_TRUE.html#PETSC_TRUE>);
>> Best Regards,
>> John
>> On Mon, Jun 20, 2011 at 2:42 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>> Hi folks,
>>> I've noticed that MatSetValues explicitly inserts zeros in the matrix if
>>> an element is really zero. Is there a way to drop elements (or not save them
>>> in the first place) that are below a certain tolerance? I realize one way of
>>> doing it is in the application code and when using MatSetValues but I'm just
>>> wondering if PETSc has a function for it?
>>> Thanks,
>>> Mohammad
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110620/0a470699/attachment.htm>
