[petsc-users] Output question for ex29.
Alan Wei zhenglun.wei at gmail.com
Thu Jun 16 16:49:24 CDT 2011
    I still have some problem with the output by using VecView(). I read its
source code but still confusing.
1) Does it just execute in 0 rank process after a MPI reduce or it execute
in every process;
2) for every execution of VecView, does it loop 'i' first or 'j' first if it
is x[j][i] in VecView(x,viewer). There is a minor question here. If VecView
does do loop, is it generally faster than that I do loop by for() command
manually ^_^ I believe it is, but I want to confirm it;
3) the VTK file output by VecView is a single column file with some header
content in the beginning. I want a 2 column file with, say MPI rank number
as the first column, can I do that? Could you please suggest a function to
call or I need to loop it by myself.
thanks in advance, ^_^
Alan
> On Fri, Jun 10, 2011 at 5:03 PM, Alan Wei <zhenglun.wei at gmail.com> wrote:
>> Oh, I got it. Indeed I found the original subroutine has the coordinate.
>> However, I may not need it since I want to plot it to a software named:
>> Tecplot. It needs data only. Thanks a lot, Matt.
>> sincerely,
>> Alan
>> On Fri, Jun 10, 2011 at 4:57 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Jun 10, 2011 at 4:54 PM, Alan Wei <zhenglun.wei at gmail.com>wrote:
>>>> oh, really. what do you meant 'valid'? it is created and data is inside.
>>>> If I have to use it, what should I do for this function? actually, I do not
>>>> have any thing in 'DM' format other than the 'da'. However, the 'da' does
>>>> not contain anything. >_<
>>> A VTK file must have a mesh in it. If you have not used VTK before, I do
>>> not think you should start with this function.
>>>    Matt
>>>> Alan
>>>> On Fri, Jun 10, 2011 at 4:44 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Fri, Jun 10, 2011 at 4:40 PM, Alan Wei <zhenglun.wei at gmail.com>wrote:
>>>>>> Thanks, Matt. I appreciate a lot for your help. I just delete 'DMView'
>>>>>> part since I do not need to see the plot of 'dm'. Right now it really plot
>>>>>> out everything.
>>>>> Without the DMView(), the VTK file will not be valid.
>>>>>   Matt
>>>>>> ^_^ thank you so much, again.
>>>>>> Alan
>>>>>> On Fri, Jun 10, 2011 at 4:26 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Fri, Jun 10, 2011 at 4:18 PM, Alan Wei <zhenglun.wei at gmail.com>wrote:
>>>>>>>> Here is my code right now, and the error message is attached. ^_^
>>>>>>>> PetscErrorCode VecView_VTK(Vec x, const char filename[], const char
>>>>>>>> bcName[])
>>>>>>>>   MPI_Comm           comm;
>>>>>>>>   DM                 da;
>>>>>>>>   Vec                coords;
>>>>>>>>   PetscViewer        viewer;
>>>>>>>>   PetscScalar       *array, *values;
>>>>>>>>   PetscInt           n, N, maxn, mx, my, dof;
>>>>>>>>   PetscInt           i, p;
>>>>>>>>   MPI_Status         status;
>>>>>>>>   PetscMPIInt        rank, size, tag, nn;
>>>>>>>>   PetscErrorCode     ierr;
>>>>>>>>   PetscFunctionBegin;
>>>>>>>>   PetscViewerASCIIOpen(PETSC_COMM_WORLD, filename, &viewer);
>>>>>>> ALWAYS check the return values:
>>>>>>>    ierr = PetscVIewerASCIIOpen(PETSC_COMM_WORLD, filename,
>>>>>>> &viewer);CHKERRQ(ierr);
>>>>>>> Do this for all the function calls.
>>>>>>>>   PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_VTK);
>>>>>>>>   DMView(x, viewer);
>>>>>>> The first argument here is a Vec, x, not the DM. Pass in the DM as
>>>>>>> well.
>>>>>>>    Matt
>>>>>>>>   VecView(x, viewer);
>>>>>>>>   PetscViewerDestroy(&viewer);
>>>>>>>>   PetscFunctionReturn(0);
>>>>>>>> thanks a lot,
>>>>>>>> Alan
>>>>>>>> On Fri, Jun 10, 2011 at 4:03 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Fri, Jun 10, 2011 at 3:47 PM, Alan Wei <zhenglun.wei at gmail.com>wrote:
>>>>>>>>>> Thanks, Matt. You're brilliant.
>>>>>>>>>>    I re-write it and the subroutine is like this. It indeed works.
>>>>>>>>>> However, there are two questions.
>>>>>>>>>> char bcName[])
>>>>>>>>>>   MPI_Comm           comm;
>>>>>>>>>>   DM                 da;
>>>>>>>>>>   Vec                coords;
>>>>>>>>>>   PetscViewer        viewer;
>>>>>>>>>>   PetscInt           i, p;
>>>>>>>>>>   MPI_Status         status;
>>>>>>>>>>   PetscFunctionBegin;
>>>>>>>>>>   PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_MATLAB);
>>>>>>>>> This still reads ASCII_MATLAB. It should be ASCII_VTK. I put that
>>>>>>>>> in my last email.
>>>>>>>>>>    DMView(x, viewer);
>>>>>>>>>>   VecView(x, PETSC_VIEWER_STDOUT_SELF);
>>>>>>>>> This should be 'viewer', not PETSC_VIEWER_STDOUT_SELF.
>>>>>>>>>> 1) It does plot out the matrix to the console, but it does not
>>>>>>>>>> create the file and write it to the file;
>>>>>>>>> There is nothing to do with any matrix in this function, only a
>>>>>>>>> vector. The vector is written to the
>>>>>>>>> console because the argument is wrong above.
>>>>>>>>>> 2) everytime I execute it, it pop up a error message at the end of
>>>>>>>>>> the computation, as I attached here.
>>>>>>>>>>    Could you please help me about these. ^_^
>>>>>>>>> Its taking forever to download this message (3M) so I cannot see
>>>>>>>>> the error right now.
>>>>>>>>>    Matt
>>>>>>>>>> thanks in advance,
>>>>>>>>>> Alan
>>>>>>>>>> On Fri, Jun 10, 2011 at 3:23 PM, Matthew Knepley <
>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>> On Fri, Jun 10, 2011 at 3:16 PM, Alan Wei <
>>>>>>>>>>>> ooops, sorry, here it is.
>>>>>>>>>>> You did not pass a valid communicator to PetscVIewerASCIIOpen().
>>>>>>>>>>> Use PETSC_COMM_WORLD.
>>>>>>>>>>>    Matt
>>>>>>>>>>>> ^_^
>>>>>>>>>>>> Alan
>>>>>>>>>>>> On Fri, Jun 10, 2011 at 3:09 PM, Matthew Knepley <
>>>>>>>>>>>>> On Fri, Jun 10, 2011 at 3:05 PM, <zhenglun.wei at gmail.com>wrote:
>>>>>>>>>>>>>> Dear Matt,
>>>>>>>>>>>>>> Following your suggestions, I modified the VecView_VTK in
>>>>>>>>>>>>>> /src/ksp/ksp/example/tutorial/ex29.c to
>>>>>>>>>>>>>> PetscFunctionBegin;
>>>>>>>>>>>>>> PetscViewerASCIIOpen(comm, filename, &viewer);
>>>>>>>>>>>>> I told you to use ASCII_VTK, not ASCII_MATLAB.
>>>>>>>>>>>>>> DMView(x, viewer);
>>>>>>>>>>>>>> VecView(x, PETSC_VIEWER_STDOUT_WORLD);
>>>>>>>>>>>>>> However, I always give me some error. Could you please briefly
>>>>>>>>>>>>>> check if there is any obvious coding problem here.
>>>>>>>>>>>>> How can I possibly know what went wrong if you do not send the
>>>>>>>>>>>>> ENTIRE error message.
>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>> thanks,
>>>>>>>>>>>>>> Alan
>>>>>>>>>>>>>> On , Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>>>>>>>>> > On Thu, Jun 9, 2011 at 6:18 PM, Matthew Knepley
>>>>>>>>>>>>>> > On Thu, Jun 9, 2011 at 6:01 PM, zhenglun.wei at gmail.com>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> > Dear Sir/Madam,
>>>>>>>>>>>>>> > I'm still studying on the ex29 of
>>>>>>>>>>>>>> /src/ksp/ksp/example/tutorial. Before I met a problem on VecView_VTK in
>>>>>>>>>>>>>> parallel computation. I'm trying to modify it in order to output some data
>>>>>>>>>>>>>> from the computation.
>>>>>>>>>>>>>> > Here is a better answer. If you want output, throw away this
>>>>>>>>>>>>>> old function which is broken, and use
>>>>>>>>>>>>>> >   PetscViewerASCIIOpen()
>>>>>>>>>>>>>> >   PetscViewerASCIISetFormat(PETSC_VIEWER_ASCII_VTK)
>>>>>>>>>>>>>> >   DMView()
>>>>>>>>>>>>>> >   VecView()
>>>>>>>>>>>>>> >   PetscViewerDestroy()
>>>>>>>>>>>>>> >     Thanks,
>>>>>>>>>>>>>> >        Matt
>>>>>>>>>>>>>> > 1) My first questions is that what does this section do in
>>>>>>>>>>>>>> VecView_VTK:
>>>>>>>>>>>>>> > 272: MPI_Comm_rank(comm, &rank);
>>>>>>>>>>>>>> > 273: MPI_Comm_size(comm, &size);
>>>>>>>>>>>>>> > 274: MPI_Reduce(&n, &maxn, 1, MPIU_INT, MPI_MAX, 0, comm);
>>>>>>>>>>>>>> > 275: tag = ((PetscObject) viewer)->tag;
>>>>>>>>>>>>>> > 276: if (!rank) {
>>>>>>>>>>>>>> > 277: PetscMalloc((maxn+1) * sizeof(PetscScalar), &values);
>>>>>>>>>>>>>> > 278: for(i = 0; i 279: PetscViewerASCIIPrintf(viewer,
>>>>>>>>>>>>>> "%G\n", PetscRealPart(array[i]));
>>>>>>>>>>>>>> > 280: }
>>>>>>>>>>>>>> > 281: for(p = 1; p 282: MPI_Recv(values, (PetscMPIInt) n,
>>>>>>>>>>>>>> MPIU_SCALAR, p, tag, comm, &status);
>>>>>>>>>>>>>> > 283: MPI_Get_count(&status, MPIU_SCALAR, &nn);
>>>>>>>>>>>>>> > 284: for(i = 0; i
>>>>>>>>>>>>>> > 285: PetscViewerASCIIPrintf(viewer, "%G\n",
>>>>>>>>>>>>>> > 286: }
>>>>>>>>>>>>>> > 287: }
>>>>>>>>>>>>>> > 288: PetscFree(values);
>>>>>>>>>>>>>> > 289: } else {
>>>>>>>>>>>>>> > 290: MPI_Send(array, n, MPIU_SCALAR, 0, tag, comm);
>>>>>>>>>>>>>> > 291: }
>>>>>>>>>>>>>> > What I understand is: it gather all the data from different
>>>>>>>>>>>>>> process in parallel computation, and output it to the 'viewer'. I comment
>>>>>>>>>>>>>> out everything in VecView_VTK except this part, there is no error message
>>>>>>>>>>>>>> coming up in my parallel computation so far.
>>>>>>>>>>>>>> > 2) however, I really don't know how did it split the domain
>>>>>>>>>>>>>> for parallel computation. For example, if I use 4 processes, is the domain
>>>>>>>>>>>>>> split like:
>>>>>>>>>>>>>> > The DMDA describes the domain splitting.
>>>>>>>>>>>>>> >    Matt
>>>>>>>>>>>>>> > a)
>>>>>>>>>>>>>> > 0 | 1
>>>>>>>>>>>>>> > 2 | 3
>>>>>>>>>>>>>> > b)
>>>>>>>>>>>>>> > 0 | 2
>>>>>>>>>>>>>> > 1 | 3
>>>>>>>>>>>>>> > c)
>>>>>>>>>>>>>> > 0 | | 2 | |
>>>>>>>>>>>>>> > | 1 | | 3 |
>>>>>>>>>>>>>> > d)
>>>>>>>>>>>>>> > 0
>>>>>>>>>>>>>> > 1
>>>>>>>>>>>>>> > 2
>>>>>>>>>>>>>> > 3
>>>>>>>>>>>>>> > thanks in advance,
>>>>>>>>>>>>>> > Alan
>>>>>>>>>>>>>> > What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>>>>>>> > -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110616/b0a62af3/attachment-0001.htm>
