[petsc-users] Getting access to matrix rows without and setting values simultaneously
    Jed Brown
    jed at 59A2.org
    Thu Jun 16 10:40:07 CDT 2011
On Thu, Jun 16, 2011 at 17:34, Matthew Knepley <knepley at gmail.com> wrote:
> Yes, you can do MF applications of A' A. You could just make a MatShell
> that called MatMult and MatMultTranspose.
MatShell is not necessary, just use MatCreateTranspose().
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/Mat/MatCreateTranspose.html
But I think Alexander is clear on that part.
> For modifying the matrix, MatGetRow() IF you are using an AIJ matrix,
> return a pointer directly to the values.
This is only for SeqAIJ.
Alexander, could you clarify where in the Gauss-Newton procedure you
outlined is the dense matrix on which you need to do the nonlinear row
operation?
Also, the matrix A'*A has a huge null space. What sort of regularization are
you using.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110616/9c5bc937/attachment.htm>
