[petsc-users] Getting access to matrix rows without and setting values simultaneously
Alexander Grayver agrayver at gfz-potsdam.de
Thu Jun 16 10:16:20 CDT 2011
Jed, thanks a lot for paper, it seems to be very good!
You're right, there are ways to avoid calculating the whole A, but there
are actually advantages having A computed, which you don't have without
A being computed (at least with approaches I know so far). I know
several technique from paper you cited, maybe they could be better (I
personally believe they are not), but anyway now I'm at the point when
no serious changes are reasonable.
That is right, F is nonlinear. The adjoint in my case costs the same as
forward problem. I can afford A for my problems. The only thing which is
really has to be avoided is the explicit assembling of A'*A in
Gauss-Newton. That I want to do using matrix-free formulation and one of
the iterative solvers from petsc. Would that be possible? If not, then I
really should think about different approach, maybe one presented in
paper you cited.
Alexander
On 16.06.2011 16:38, Jed Brown wrote:
> On Thu, Jun 16, 2011 at 15:43, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     Let's say we have a discretized model of some physical parameter m
>     (say acoustic velocity). Number of model parameters is N. We need
>     to take M measurements d within model (say time traveling of
>     acoustic wave) based on M different sets of receiver/source positions.
>     In our case N >> M (e.g. 10^7 >> 10^3).
>     We have operator F (which might linear or not) that defines
>     relationship between m and d:
>     d=F(m)
>     The operator F is just a system of equations actually. I have no
>     problem now to solve it for any m.
>     What I need now is to compute the variation of this operator:
>     A = \frac{\partial d_i}{\partial m_j}, for all i=1..M, j=1..N
>     After some maths this calculation could be reformulated as a
>     triple product:
>     A_i = C*F(m)^-1*v
>     Where C some sparse matrix.
>     Once the A is computed I want to solve another problem:
>     (A'*A)b=A'*r
>     Which is a Gauss-Newton system now,
>     A'*A is truncated Hessian,
>     A'*r is gradient,
>     r = d - d_obs, where d_obs is the real observed data.
>     b -- model change which have to applied to original model m in
>     order to explain your observed data better
> Excellent, great description.
> It looks to me like you are assembling A because you want to be able
> to multiply by A' (which you can't do with finite differencing). But
> there is a very efficient way to apply A' that does not require
> assembling it: automatic differentiation. The adjoint costs about
> three times as much as a single forward solve. Depending on the nature
> of the nonlinearities in your problem, it may also be reasonably easy
> to write the adjoint without using AD.
> You shouldn't need to assemble any of these matrices to solve the
> optimization/inverse problem. Assembling the matrices seriously limits
> scalability and there are optimal algorithms that don't use them.
> Depending on the problem, you may need a preconditioner for the
> reduced Hessian, but that can also be done without assembling it.
> I imagine that F() is nonlinear. The adjoint of the nonlinear solve is
> the adjoint of the Jacobian at the converged state.
> For more specifics on algorithms and pointers to the literature, you
> could look at this paper and some of the more specific applications it
> cites.
> http://users.ices.utexas.edu/~omar/papers/siam-par-pde-opt.pdf
> <http://users.ices.utexas.edu/%7Eomar/papers/siam-par-pde-opt.pdf>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110616/0f0ca3a7/attachment-0001.htm>
