[petsc-users] long int
Jed Brown
jed at 59A2.org
Sun Jun 12 13:45:14 CDT 2011
On Sun, Jun 12, 2011 at 20:38, Matthew Knepley <knepley at gmail.com> wrote:
> The words here are too imprecise:
> short int: A 2 byte integer
> long int: A 4 byte integer
No, "long int" must be at least 4 bytes, but it may be larger. "long int" is
8 bytes on 64-bit Linux and OS X. It is 4 bytes on LLP64 such as 64-bit
Windows.
> int: An integer which can be short or long, depending on the
> compiler, but most often long int today
Int must be at least 2 bytes. In practice, it is either 4 or 8 bytes. Int
cannot be larger than long. It is 4 bytes on the most commonly used
platforms.
> long long int: An 8 byte integer
This is a minimum, but I don't know any architectures that make it larger.
> The --with-64-bit-indices flag gives long long ints. If you have > 2B
> unknowns, use this, otherwise don't. Yes, it slows things down.
In particular, it doubles the amount of memory required for column indices
in the matrix and for index sets. This is not a huge difference, but it is
noticeable.
> On every 64-bit architecture I know, 'int' is still 'long int', not 'long
> long int'. The only thing that is 64-bit is the pointers.
Nonsense, sizeof(long) is 8 on YOUR COMPUTER, Matt.
sizeof(int) is 4 on your computer.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110612/05cedeac/attachment.htm>
