[petsc-users] Output question for ex29.
Matthew Knepley
knepley at gmail.com
Fri Jun 10 15:23:13 CDT 2011
On Fri, Jun 10, 2011 at 3:16 PM, Alan Wei <zhenglun.wei at gmail.com> wrote:
> ooops, sorry, here it is.
You did not pass a valid communicator to PetscVIewerASCIIOpen(). Use
PETSC_COMM_WORLD.
Matt
> ^_^
> Alan
> On Fri, Jun 10, 2011 at 3:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Fri, Jun 10, 2011 at 3:05 PM, <zhenglun.wei at gmail.com> wrote:
>>> Dear Matt,
>>> Following your suggestions, I modified the VecView_VTK in
>>> /src/ksp/ksp/example/tutorial/ex29.c to
>>> PetscFunctionBegin;
>>> PetscViewerASCIIOpen(comm, filename, &viewer);
>>> PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_MATLAB);
>> I told you to use ASCII_VTK, not ASCII_MATLAB.
>>> DMView(x, viewer);
>>> VecView(x, PETSC_VIEWER_STDOUT_WORLD);
>>> PetscViewerDestroy(&viewer);
>>> PetscFunctionReturn(0);
>>> However, I always give me some error. Could you please briefly check if
>>> there is any obvious coding problem here.
>> How can I possibly know what went wrong if you do not send the ENTIRE
>> error message.
>> Matt
>>> thanks,
>>> Alan
>>> On , Matthew Knepley <knepley at gmail.com> wrote:
>>> > On Thu, Jun 9, 2011 at 6:18 PM, Matthew Knepley knepley at gmail.com>
>>> wrote:
>>> > On Thu, Jun 9, 2011 at 6:01 PM, zhenglun.wei at gmail.com> wrote:
>>> > Dear Sir/Madam,
>>> > I'm still studying on the ex29 of /src/ksp/ksp/example/tutorial. Before
>>> I met a problem on VecView_VTK in parallel computation. I'm trying to modify
>>> it in order to output some data from the computation.
>>> > Here is a better answer. If you want output, throw away this old
>>> function which is broken, and use
>>> > PetscViewerASCIIOpen()
>>> > PetscViewerASCIISetFormat(PETSC_VIEWER_ASCII_VTK)
>>> > DMView()
>>> > VecView()
>>> > PetscViewerDestroy()
>>> > Thanks,
>>> > Matt
>>> > 1) My first questions is that what does this section do in VecView_VTK:
>>> > 272: MPI_Comm_rank(comm, &rank);
>>> > 273: MPI_Comm_size(comm, &size);
>>> > 274: MPI_Reduce(&n, &maxn, 1, MPIU_INT, MPI_MAX, 0, comm);
>>> > 275: tag = ((PetscObject) viewer)->tag;
>>> > 276: if (!rank) {
>>> > 277: PetscMalloc((maxn+1) * sizeof(PetscScalar), &values);
>>> > 278: for(i = 0; i 279: PetscViewerASCIIPrintf(viewer, "%G\n",
>>> PetscRealPart(array[i]));
>>> > 280: }
>>> > 281: for(p = 1; p 282: MPI_Recv(values, (PetscMPIInt) n, MPIU_SCALAR,
>>> p, tag, comm, &status);
>>> > 283: MPI_Get_count(&status, MPIU_SCALAR, &nn);
>>> > 284: for(i = 0; i
>>> > 285: PetscViewerASCIIPrintf(viewer, "%G\n", PetscRealPart(array[i]));
>>> > 286: }
>>> > 287: }
>>> > 288: PetscFree(values);
>>> > 289: } else {
>>> > 290: MPI_Send(array, n, MPIU_SCALAR, 0, tag, comm);
>>> > 291: }
>>> > What I understand is: it gather all the data from different process in
>>> parallel computation, and output it to the 'viewer'. I comment out
>>> everything in VecView_VTK except this part, there is no error message coming
>>> up in my parallel computation so far.
>>> > 2) however, I really don't know how did it split the domain for
>>> parallel computation. For example, if I use 4 processes, is the domain split
>>> like:
>>> > The DMDA describes the domain splitting.
>>> > Matt
>>> > a)
>>> > 0 | 1
>>> > 2 | 3
>>> > b)
>>> > 0 | 2
>>> > 1 | 3
>>> > c)
>>> > 0 | | 2 | |
>>> > | 1 | | 3 |
>>> > d)
>>> > 0
>>> > 1
>>> > 2
>>> > 3
>>> > thanks in advance,
>>> > Alan
>>> > What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> > -- Norbert Wiener
>>> experiments lead.
>>> > -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110610/e0011e41/attachment.htm>
