[petsc-users] Output question for ex29.
zhenglun.wei at gmail.com
Fri Jun 10 15:05:21 CDT 2011
Dear Matt,
Following your suggestions, I modified the VecView_VTK in
/src/ksp/ksp/example/tutorial/ex29.c to
PetscFunctionBegin;
PetscViewerASCIIOpen(comm, filename, &viewer);
PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_MATLAB);
DMView(x, viewer);
VecView(x, PETSC_VIEWER_STDOUT_WORLD);
PetscViewerDestroy(&viewer);
PetscFunctionReturn(0);
However, I always give me some error. Could you please briefly check if
there is any obvious coding problem here.
thanks,
Alan
On , Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 9, 2011 at 6:18 PM, Matthew Knepley knepley at gmail.com> wrote:
> On Thu, Jun 9, 2011 at 6:01 PM, zhenglun.wei at gmail.com> wrote:
> Dear Sir/Madam,
> I'm still studying on the ex29 of /src/ksp/ksp/example/tutorial. Before I
> met a problem on VecView_VTK in parallel computation. I'm trying to
> modify it in order to output some data from the computation.
> Here is a better answer. If you want output, throw away this old function
> which is broken, and use
> PetscViewerASCIIOpen()
> PetscViewerASCIISetFormat(PETSC_VIEWER_ASCII_VTK)
> DMView()
> VecView()
> PetscViewerDestroy()
> Thanks,
> Matt
> 1) My first questions is that what does this section do in VecView_VTK:
> 272: MPI_Comm_rank(comm, &rank);
> 273: MPI_Comm_size(comm, &size);
> 274: MPI_Reduce(&n, &maxn, 1, MPIU_INT, MPI_MAX, 0, comm);
> 275: tag = ((PetscObject) viewer)->tag;
> 276: if (!rank) {
> 277: PetscMalloc((maxn+1) * sizeof(PetscScalar), &values);
> 278: for(i = 0; i 279: PetscViewerASCIIPrintf(viewer, "%G\n",
> PetscRealPart(array[i]));
> 280: }
> 281: for(p = 1; p 282: MPI_Recv(values, (PetscMPIInt) n, MPIU_SCALAR, p,
> tag, comm, &status);
> 283: MPI_Get_count(&status, MPIU_SCALAR, &nn);
> 284: for(i = 0; i
> 285: PetscViewerASCIIPrintf(viewer, "%G\n", PetscRealPart(array[i]));
> 286: }
> 287: }
> 288: PetscFree(values);
> 289: } else {
> 290: MPI_Send(array, n, MPIU_SCALAR, 0, tag, comm);
> 291: }
> What I understand is: it gather all the data from different process in
> parallel computation, and output it to the 'viewer'. I comment out
> everything in VecView_VTK except this part, there is no error message
> coming up in my parallel computation so far.
> 2) however, I really don't know how did it split the domain for parallel
> computation. For example, if I use 4 processes, is the domain split like:
> The DMDA describes the domain splitting.
> Matt
> a)
> 0 | 1
> 2 | 3
> b)
> 0 | 2
> 1 | 3
> c)
> 0 | | 2 | |
> | 1 | | 3 |
> d)
> 0
> 1
> 2
> 3
> thanks in advance,
> Alan
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110610/a478b8c4/attachment.htm>
