[petsc-users] Advise on choice of iterative solver
Matthew Knepley
knepley at gmail.com
Wed Jun 8 07:51:24 CDT 2011
On Wed, Jun 8, 2011 at 7:34 AM, Klaus Zimmermann <
klaus.zimmermann at physik.uni-freiburg.de> wrote:
> Hi Jed, Hi Matthew,
> thanks for your quick responses!
> On 06/08/2011 02:23 PM, Jed Brown wrote:
> > On Wed, Jun 8, 2011 at 14:17, Matthew Knepley <knepley at gmail.com
> > <mailto:knepley at gmail.com>> wrote:
> > However, you might look at Elemental
> > (http://code.google.com/p/elemental/) which solves the complex
> > symmetric eigenproblem and is very scalable.
> > Note that Elemental is for dense systems.
> > To solve your problem, it's important to know where it came from. The
> > average number of nonzeros per row doesn't tell us anything about it's
> > mathematical structure which is needed to design a good solver.
> We are doing quantum mechanical ab initio calculations. The Matrix stems
> from a two particle Hamiltonian in a product basis. Thus we have basis
> vectors S_{nm}. The sparseness is now due to the fact that the matrix
> element <S_{nm}|H|S_{n'm'}> can only be non-zero if |n-n'|<4 and |m-m'|<4.
> Does this help or do you need more information? Like the matrix
> construction code?
This does not just sound sparse, it sounds banded. Is this true? If so, you
can use dense, banded solvers instead.
Matt
> Thanks,
> Klaus
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110608/8c9238b5/attachment.htm>
