[petsc-users] A question on "memory access out of range" in mpi running
Jed Brown
jed at 59A2.org
Wed Jun 1 11:58:16 CDT 2011
On Wed, Jun 1, 2011 at 18:50, Matthew Knepley <knepley at gmail.com> wrote:
> No, there is some problem with the VTK output for that. You can comment it
> out. I will look at fixing it.
Even if it didn't deadlock, that code never worked since it is totally wrong
for parallel.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110601/1e66a176/attachment.htm>
