[petsc-users] best PETSC solver for long nozzles
Stephen Wornom
stephen.wornom at inria.fr
Sat Jan 29 04:26:40 CST 2011
Geometry: Tube with L/D is >> 1
Characteristics:
-Unstructured partitioned mesh with 500K vertices globally.
-The tube wall is heated, thus solution evolves in the x-direction.
-X is the dominant flow direction.
-Seek steady solution using the time advancing scheme with a low Mach
number preconditionner.
*Question*: Which *PETSC* solver would give the best convergence?
Stephen
p.s.
My present solver does not take into consideration that the flow has a
dominant flow direction (x).
Thus the convergence is very slow, 30000 time steps using 64-processors
with a CFLmax= 50 applied in each cell. At 15000 time steps the 0-L/2
portion of the tube is converged with an additional 15000 time steps
needed to converge the L/2-L part of the tube.
2004 route des lucioles - BP93
Sophia Antipolis
06902 CEDEX
Tel: 04 92 38 50 54
Fax: 04 97 15 53 51
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110129/0fdceea5/attachment.vcf>
