[petsc-users] How to symmetrical the pattern of anunsymmetrical matrix
Gong Ding
gdiso at ustc.edu
Fri Jan 28 21:27:53 CST 2011
> 2011/1/26 Gong Ding <gdiso at ustc.edu>
>> I have unsymmetrical jacobian matrix in MPIAIJ format (it is nearlly
>> symmetric, I guess). I'd like to pad it to symmetrical pattern by just add 0
>> to corresponding matrix entry, which is required to some matrix partition
>> step.
> How are you obtaining the matrix? The best way is to preallocate those
> extra zeros.
Yes, it is the problem. I have to build the pattern of symmetrical matrix for memory allocation from the unsymmetrical matrix.
I don't konw how to do it with petsc API. Any good idea?
After build the symmetrical matrix, things are easy.
> A traditional purely algebraic way is to add the transpose (zeroed in this
> case), but transpose is a bad operation to perform in parallel so I would
> try to avoid it.
