[petsc-users] reuse of KSP is sometimes harmful
    Matthew Knepley
    knepley at gmail.com
    Fri Jan 28 14:31:45 CST 2011
2011/1/28 Cristian Tibirna <ctibirna at giref.ulaval.ca>
> Hello
> We use PETSc-2.3.3-p15 (long story...) embedded inside a large FE code from
> which it would be difficult for me to extract exact PETSc code. Sorry for
> this. But we have a rather ugly problem and I would like to know just if it
> is
> our use or there might be some intrinsic problem.
> What we do, in principle, is
> 1) create a KSP, a Mat and some Vec
> 2) start a loop (e.g. a home-made nonlinear solver)
>        inside the loop:
>        2.1)  reassemble Mat either through one of two variants:
>                a) sometimes the nonzero structure is constant
>                        only the assembled values are changing
>                b) sometimes the nonzero structure changes too,
>                        which brings us to create and use a new Mat
>        2.2) reassemble the rhs Vec
>        2.3) on fait un KSPSetOperators avec
>        2.4) solve the system and get the solution (or correction)
> NOTE: As you see, the KSP is created only once then reused.
> NOTE: the point b) -- the main issue of this email -- consists most usually
> of
> a MatPtAP operation, which naturally gives us a new Mat with new non-zero
> structure.
> If we do the above with the variant a), all works perfectly.
> if we do the variant b), the solution is completely aberant.
That should work. This is not really enough of a description for us to debug
the problem.
I suggest using -pc_type lu -ksp_type preonly for an exact solution, and
then check the
solution for doing a MatMult(). Usually, this problem occurs because you
forget to call
KSPSetOperators().
   Matt
> The only workaround we found was to recreate the KSP at each iteration in
> the
> loop. Then the solution vector is correctly computed.
> What gives?
> Cristian Tibirna                                (1-418-) 656-2131 / 4340
>  Laval University - Quebec, CAN ... http://www.giref.ulaval.ca/~ctibirna
>  Research professional at GIREF ... ctibirna at giref.ulaval.ca
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110128/36b10b25/attachment.htm>
