[petsc-users] Problem on LU factorization
    Rongliang Chen
    rongliang.chan at gmail.com
    Wed Jan 26 12:45:46 CST 2011
Hello,
Thank you for all your reply.
I have tested my code using the debug version and there is the same problem.
The error message is attached.
The problem I am solving is a nonlinear system. I use inexact Newton method
with preconditioned restarted GMRES (-ksp_type gnres) for the linear system.
The preconditioner is ASM (-pc_type asm) and the sub problem is solved by LU
(-sub_pc_type lu). Since there are zeros on the diagonal, I use the command
line  "-sub_pc_factor_shift_amount 1.e-10 -sub_pc_factor_shift_type nonzero"
to add a small number to the zero diagonals.
I found some error message in the configure.log(see bellow). Could this be a
problem?
# Directories
 files,
# %s (device %ld, inode %ld):
 impossibilities
 so far.
 impossibilities in %lu directories.
# %s: could not be stat'd.
# %s (device %ld, inode %ld): could not be opened.
Recursive variable `%s' references itself (eventually)
warning: undefined variable `%.*s'
unterminated variable reference
%s:%s
 | %s
#  Implicit rule search has been done.
#  Implicit rule search has not been done.
#  Modification time never checked.
#  File does not exist.
#  Last modified %s
#  File has been updated.
#  File has not been updated.
#  Invalid value in `update_status' member!
# Not a target:
#  Also makes:
#  File is an intermediate prerequisite.
#  Implicit/static pattern stem: `%s'
#  A default or MAKEFILES makefile.
#  Command-line target.
#  Phony target (prerequisite of .PHONY).
#  Precious file (prerequisite of .PRECIOUS).
#  Failed to be updated.
#  Successfully updated.
#  Needs to be updated (-q is set).
question_flag
file.c
print_file
#  Dependencies commands running (THIS IS A BUG).
#  File is very old.
#  Commands currently running (THIS IS A BUG).
#  Invalid value in `command_state' member!
# Files
# files hash-table stats:
%04d-%02d-%02d %02d:%02d:%02d
.%09d
%s: Timestamp out of range; substituting %s
Current time
*** Deleting intermediate file `%s'
Removing intermediate files...
can't rename single-colon `%s' to double-colon `%s'
Commands were specified for file `%s' at %s:%lu,
but `%s' is now considered the same file as `%s'.
Commands for `%s' will be ignored in favor of those for `%s'.
Commands for file `%s' were found by implicit rule search,
can't rename double-colon `%s' to single-colon `%s'
TEST checkDynamicLinker from
config.setCompilers(/home/rchen/soft/petsc-3.1-p7-nodebug/config/BuildSystem/config/setCompilers.py:1257)
TESTING: checkDynamicLinker from
config.setCompilers(config/BuildSystem/config/setCompilers.py:1257)
  Check that the linker can produce dynamic libraries
Checking for header: dlfcn.h
sh: /contrib/bgl/bin/mpxlc -E   conftest.c
Executing: /contrib/bgl/bin/mpxlc -E   conftest.c
sh:
Possible ERROR while running preprocessor: "conftest.c", line 3.10: 1506-296
(S) #include file <dlfcn.h> not found.
ret = 256
error message = {"conftest.c", line 3.10: 1506-296 (S) #include file
Source:
#include "confdefs.h"
#include "conffix.h"
#include <dlfcn.h>
      Dynamic libraries disabled since dlfcn.h was missing
Thank you!
Rongliang
> Message: 5
> Date: Tue, 25 Jan 2011 23:19:27 -0600 (CST)
> From: Satish Balay <balay at mcs.anl.gov>
> Subject: Re: [petsc-users] Problem on LU factorization
> To: Rongliang Chen <rongliang.chan at gmail.com>
> Cc: PETSc Users mail list <petsc-users at mcs.anl.gov>
> Message-ID:
>        <alpine.LFD.2.02.1101252316570.2510 at localhost6.localdomain6>
> Content-Type: TEXT/PLAIN; charset=US-ASCII
> I don't see anything obviously wrong with this build
> I guess the other thing to do is to build debug version on the machine
> and run in a debugger to determine the problem. [I believe there is a
> way to debug on bgl..]
> Satish
> Message: 7
> Date: Wed, 26 Jan 2011 09:39:17 -0600
> From: Hong Zhang <hzhang at mcs.anl.gov>
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
>        <AANLkTikJJCFQnESxfTMrwgiTjHMmGSoYDNFG6GivQO84 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> As Matt said, this is no enough information on what solver combination
> is being used.
> Since superlu_dist works while petsc/superlu's sequential lu fails,
> you might need
> parallel lu, or shift if zero pivot causes crash. As suggested by Satish,
> run code in debug version from which informative error display would be
> shown.
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110126/471cb754/attachment-0001.htm>
/bin/bash: SHELL: readonly variable
/bin/bash: PATH: readonly variable
Can't expand MemType 1: jcol 25274
[43]PETSC ERROR: ------------------------------------------------------------------------
[43]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[43]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[43]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[43]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[43]PETSC ERROR: likely location of problem given in stack below
[43]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[43]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[43]PETSC ERROR:       INSTEAD the line number of the start of the function
[43]PETSC ERROR:       is given.
[43]PETSC ERROR: [43] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[43]PETSC ERROR: [43] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[43]PETSC ERROR: --------------------- Error Message ------------------------------------
[43]PETSC ERROR: Signal received!
[43]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[43]PETSC ERROR: See docs/changes/index.html for recent updates.
[43]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[43]PETSC ERROR: See docs/index.html for manual pages.
[43]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[43]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[43]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[43]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[43]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 43[64]PETSC ERROR: [65]PETSC ERROR: [66]PETSC ERROR: [67]PETSC ERROR: ------------------------------------------------------------------------
[64]PETSC ERROR: [65]PETSC ERROR: [66]PETSC ERROR: [67]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[64]PETSC ERROR: [65]PETSC ERROR: [66]PETSC ERROR: [67]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[64]PETSC ERROR: [65]PETSC ERROR: [66]PETSC ERROR: [67]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signalor see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signalor see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[68]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: ------------------------------------------------------------------------
[68]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[68]PETSC ERROR: likely location of problem given in stack below
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[68]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[67]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#SignalNote: The EXACT line numbers in the stack are not available,
[68]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[67]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[68]PETSC ERROR:       INSTEAD the line number of the start of the function
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: likely location of problem given in stack below
[67]PETSC ERROR: likely location of problem given in stack below
      is given.
      is given.
      is given.
[68]PETSC ERROR:       is given.
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[67]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[64] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[65] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[66] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[68]PETSC ERROR: [67] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[67]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[64] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[65] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[66] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[68]PETSC ERROR: [67] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR:       INSTEAD the line number of the start of the function
[67]PETSC ERROR:       INSTEAD the line number of the start of the function
[68]PETSC ERROR: --------------------- Error Message ------------------------------------
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR:       is given.
[67]PETSC ERROR:       is given.
Signal received!
      is given.
Signal received!
      is given.
Signal received!
[68]PETSC ERROR: Signal received!
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: [68] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[67]PETSC ERROR: [69] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[71] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[70] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[68]PETSC ERROR: ------------------------------------------------------------------------
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: [68] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[67]PETSC ERROR: [69] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[71] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[70] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[68]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: --------------------- Error Message ------------------------------------
[67]PETSC ERROR: --------------------- Error Message ------------------------------------
[68]PETSC ERROR: See docs/changes/index.html for recent updates.
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: Signal received!
[67]PETSC ERROR: Signal received!
Signal received!
Signal received!
[68]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[68]PETSC ERROR: See docs/index.html for manual pages.
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[67]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: See docs/changes/index.html for recent updates.
[67]PETSC ERROR: See docs/changes/index.html for recent updates.
/home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0ND by Unknown Wed Jan 26 11:03:56 2011
[68]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0ND by Unknown Wed Jan 26 11:03:56 2011
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[67]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[68]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: See docs/index.html for manual pages.
[67]PETSC ERROR: See docs/index.html for manual pages.
[68]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[68]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NC by Unknown Wed Jan 26 11:03:56 2011
[67]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NC by Unknown Wed Jan 26 11:03:56 2011
[69]PETSC ERROR: [64]PETSC ERROR: [71]PETSC ERROR: [65]PETSC ERROR: [70]PETSC ERROR: [66]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[67]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[68]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[69]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 64[71]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 65[70]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 66Configure run at Sat Dec 25 23:04:15 2010
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 67Configure run at Sat Dec 25 23:04:15 2010
[68]PETSC ERROR: [69]PETSC ERROR: [71]PETSC ERROR: [70]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[68]PETSC ERROR: [69]PETSC ERROR: [71]PETSC ERROR: [70]PETSC ERROR: ------------------------------------------------------------------------
[68]PETSC ERROR: [69]PETSC ERROR: [71]PETSC ERROR: [70]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 68application called MPI_Abort(MPI_COMM_WORLD, 59) - process 69application called MPI_Abort(MPI_COMM_WORLD, 59) - process 71application called MPI_Abort(MPI_COMM_WORLD, 59) - process 70[4]PETSC ERROR: [5]PETSC ERROR: [12]PETSC ERROR: [7]PETSC ERROR: [6]PETSC ERROR: [13]PETSC ERROR: [14]PETSC ERROR: [15]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: [23]PETSC ERROR: [28]PETSC ERROR: [22]PETSC ERROR: [29]PETSC ERROR: [36]PETSC ERROR: [37]PETSC ERROR: [30]PETSC ERROR: [44]PETSC ERROR: [38]PETSC ERROR: [45]PETSC ERROR: [31]PETSC ERROR: [39]PETSC ERROR: [46]PETSC ERROR: [53]PETSC ERROR: [52]PETSC ERROR: [47]PETSC ERROR: [54]PETSC ERROR: [55]PETSC ERROR: [60]PETSC ERROR: [62]PETSC ERROR: [61]PETSC ERROR: [63]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: ------------------------------------------------------------------------
[2]PETSC ERROR: ------------------------------------------------------------------------
[8]PETSC ERROR: ------------------------------------------------------------------------
[3]PETSC ERROR: ------------------------------------------------------------------------
[9]PETSC ERROR: [4]PETSC ERROR: [10]PETSC ERROR: [5]PETSC ERROR: [11]PETSC ERROR: [12]PETSC ERROR: [17]PETSC ERROR: [7]PETSC ERROR: [16]PETSC ERROR: [6]PETSC ERROR: [18]PETSC ERROR: [13]PETSC ERROR: [19]PETSC ERROR: [14]PETSC ERROR: [24]PETSC ERROR: [15]PETSC ERROR: [25]PETSC ERROR: [20]PETSC ERROR: [32]PETSC ERROR: [21]PETSC ERROR: [26]PETSC ERROR: [23]PETSC ERROR: [33]PETSC ERROR: [28]PETSC ERROR: [41]PETSC ERROR: [22]PETSC ERROR: [40]PETSC ERROR: [29]PETSC ERROR: [27]PETSC ERROR: [36]PETSC ERROR: [35]PETSC ERROR: [37]PETSC ERROR: [34]PETSC ERROR: [30]PETSC ERROR: [42]PETSC ERROR: [44]PETSC ERROR: [48]PETSC ERROR: [38]PETSC ERROR: [49]PETSC ERROR: [45]PETSC ERROR: [50]PETSC ERROR: [31]PETSC ERROR: [51]PETSC ERROR: [39]PETSC ERROR: [56]PETSC ERROR: [46]PETSC ERROR: [58]PETSC ERROR: [53]PETSC ERROR: [57]PETSC ERROR: [52]PETSC ERROR: [59]PETSC ERROR: [47]PETSC ERROR: ------------------------------------------------------------------------
[54]PETSC ERROR: ------------------------------------------------------------------------
[55]PETSC ERROR: ------------------------------------------------------------------------
[60]PETSC ERROR: ------------------------------------------------------------------------
[62]PETSC ERROR: ------------------------------------------------------------------------
[61]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[1]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[2]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[8]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[3]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[9]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[10]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[11]PETSC ERROR: [4]PETSC ERROR: [17]PETSC ERROR: [5]PETSC ERROR: [16]PETSC ERROR: [12]PETSC ERROR: [18]PETSC ERROR: [7]PETSC ERROR: [19]PETSC ERROR: [6]PETSC ERROR: [24]PETSC ERROR: [13]PETSC ERROR: [25]PETSC ERROR: [14]PETSC ERROR: [15]PETSC ERROR: [20]PETSC ERROR: [21]PETSC ERROR: [32]PETSC ERROR: [23]PETSC ERROR: [26]PETSC ERROR: [28]PETSC ERROR: [33]PETSC ERROR: [22]PETSC ERROR: [41]PETSC ERROR: [29]PETSC ERROR: [40]PETSC ERROR: [36]PETSC ERROR: [27]PETSC ERROR: [37]PETSC ERROR: [35]PETSC ERROR: [30]PETSC ERROR: [34]PETSC ERROR: [44]PETSC ERROR: [42]PETSC ERROR: [38]PETSC ERROR: [48]PETSC ERROR: [45]PETSC ERROR: [49]PETSC ERROR: [31]PETSC ERROR: [50]PETSC ERROR: [39]PETSC ERROR: [51]PETSC ERROR: [46]PETSC ERROR: [56]PETSC ERROR: [53]PETSC ERROR: [58]PETSC ERROR: [52]PETSC ERROR: [57]PETSC ERROR: [47]PETSC ERROR: [59]PETSC ERROR: [54]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[55]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[60]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[62]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[61]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[63]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[8]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[9]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[10]PETSC ERROR: [4]PETSC ERROR: [11]PETSC ERROR: [5]PETSC ERROR: [17]PETSC ERROR: [12]PETSC ERROR: [16]PETSC ERROR: [7]PETSC ERROR: [18]PETSC ERROR: [6]PETSC ERROR: [19]PETSC ERROR: [13]PETSC ERROR: [24]PETSC ERROR: [14]PETSC ERROR: [25]PETSC ERROR: [15]PETSC ERROR: [32]PETSC ERROR: [20]PETSC ERROR: [26]PETSC ERROR: [21]PETSC ERROR: [33]PETSC ERROR: [23]PETSC ERROR: [41]PETSC ERROR: [28]PETSC ERROR: [40]PETSC ERROR: [22]PETSC ERROR: [27]PETSC ERROR: [29]PETSC ERROR: [35]PETSC ERROR: [36]PETSC ERROR: [34]PETSC ERROR: [37]PETSC ERROR: [42]PETSC ERROR: [30]PETSC ERROR: [48]PETSC ERROR: [44]PETSC ERROR: [49]PETSC ERROR: [38]PETSC ERROR: [50]PETSC ERROR: [45]PETSC ERROR: [51]PETSC ERROR: [31]PETSC ERROR: [56]PETSC ERROR: [39]PETSC ERROR: [58]PETSC ERROR: [46]PETSC ERROR: [57]PETSC ERROR: [53]PETSC ERROR: [59]PETSC ERROR: [52]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[47]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[54]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[55]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[60]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[62]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[61]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[63]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#SignalTry option -start_in_debugger or -on_error_attach_debugger
or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[2]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[8]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[9]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[10]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[11]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[17]PETSC ERROR: [4]PETSC ERROR: [16]PETSC ERROR: [5]PETSC ERROR: [18]PETSC ERROR: [12]PETSC ERROR: [19]PETSC ERROR: [7]PETSC ERROR: [24]PETSC ERROR: [6]PETSC ERROR: [25]PETSC ERROR: [13]PETSC ERROR: [32]PETSC ERROR: [14]PETSC ERROR: [26]PETSC ERROR: [15]PETSC ERROR: [33]PETSC ERROR: [20]PETSC ERROR: [41]PETSC ERROR: [21]PETSC ERROR: [40]PETSC ERROR: [23]PETSC ERROR: [27]PETSC ERROR: [28]PETSC ERROR: [35]PETSC ERROR: [22]PETSC ERROR: [34]PETSC ERROR: [29]PETSC ERROR: [42]PETSC ERROR: [36]PETSC ERROR: [48]PETSC ERROR: [37]PETSC ERROR: [49]PETSC ERROR: [30]PETSC ERROR: [50]PETSC ERROR: [44]PETSC ERROR: [51]PETSC ERROR: [38]PETSC ERROR: [56]PETSC ERROR: [45]PETSC ERROR: [58]PETSC ERROR: [31]PETSC ERROR: [57]PETSC ERROR: [39]PETSC ERROR: [59]PETSC ERROR: [46]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[53]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[52]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[47]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[54]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[55]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[60]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[62]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[61]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[63]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signalor try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[8]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[9]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[10]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[11]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[17]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[16]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[18]PETSC ERROR: [4]PETSC ERROR: [19]PETSC ERROR: [5]PETSC ERROR: [24]PETSC ERROR: [12]PETSC ERROR: [25]PETSC ERROR: [7]PETSC ERROR: [32]PETSC ERROR: [6]PETSC ERROR: [26]PETSC ERROR: [13]PETSC ERROR: [33]PETSC ERROR: [14]PETSC ERROR: [41]PETSC ERROR: [15]PETSC ERROR: [40]PETSC ERROR: [20]PETSC ERROR: [27]PETSC ERROR: [21]PETSC ERROR: [35]PETSC ERROR: [23]PETSC ERROR: [34]PETSC ERROR: [28]PETSC ERROR: [42]PETSC ERROR: [22]PETSC ERROR: [48]PETSC ERROR: [29]PETSC ERROR: [49]PETSC ERROR: [36]PETSC ERROR: [50]PETSC ERROR: [37]PETSC ERROR: [51]PETSC ERROR: [30]PETSC ERROR: [56]PETSC ERROR: [44]PETSC ERROR: [58]PETSC ERROR: [38]PETSC ERROR: [57]PETSC ERROR: [45]PETSC ERROR: [59]PETSC ERROR: [31]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[39]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[46]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[53]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[52]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[47]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[54]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[55]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[60]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[62]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[61]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[63]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: likely location of problem given in stack below
[2]PETSC ERROR: likely location of problem given in stack below
[8]PETSC ERROR: likely location of problem given in stack below
[3]PETSC ERROR: likely location of problem given in stack below
[9]PETSC ERROR: likely location of problem given in stack below
[10]PETSC ERROR: likely location of problem given in stack below
[11]PETSC ERROR: likely location of problem given in stack below
[17]PETSC ERROR: likely location of problem given in stack below
[16]PETSC ERROR: likely location of problem given in stack below
[18]PETSC ERROR: likely location of problem given in stack below
[19]PETSC ERROR: likely location of problem given in stack below
[24]PETSC ERROR: [4]PETSC ERROR: [25]PETSC ERROR: [5]PETSC ERROR: [32]PETSC ERROR: [12]PETSC ERROR: [26]PETSC ERROR: [7]PETSC ERROR: [33]PETSC ERROR: [6]PETSC ERROR: [41]PETSC ERROR: [13]PETSC ERROR: [40]PETSC ERROR: [14]PETSC ERROR: [27]PETSC ERROR: [15]PETSC ERROR: [35]PETSC ERROR: [20]PETSC ERROR: [34]PETSC ERROR: [21]PETSC ERROR: [42]PETSC ERROR: [23]PETSC ERROR: [48]PETSC ERROR: [28]PETSC ERROR: [49]PETSC ERROR: [22]PETSC ERROR: [50]PETSC ERROR: [29]PETSC ERROR: [51]PETSC ERROR: [36]PETSC ERROR: [56]PETSC ERROR: [37]PETSC ERROR: [58]PETSC ERROR: [30]PETSC ERROR: [57]PETSC ERROR: [44]PETSC ERROR: [59]PETSC ERROR: [38]PETSC ERROR: likely location of problem given in stack below
[45]PETSC ERROR: likely location of problem given in stack below
[31]PETSC ERROR: likely location of problem given in stack below
[39]PETSC ERROR: likely location of problem given in stack below
[46]PETSC ERROR: likely location of problem given in stack below
[53]PETSC ERROR: likely location of problem given in stack below
[52]PETSC ERROR: likely location of problem given in stack below
[47]PETSC ERROR: likely location of problem given in stack below
[54]PETSC ERROR: likely location of problem given in stack below
[55]PETSC ERROR: likely location of problem given in stack below
[60]PETSC ERROR: likely location of problem given in stack below
[62]PETSC ERROR: likely location of problem given in stack below
[61]PETSC ERROR: likely location of problem given in stack below
[63]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[1]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[2]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[8]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[3]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[9]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[10]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[11]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[17]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[16]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[18]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[19]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[24]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[25]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[32]PETSC ERROR: [4]PETSC ERROR: [26]PETSC ERROR: [5]PETSC ERROR: [33]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[41]PETSC ERROR: [12]PETSC ERROR: [40]PETSC ERROR: [7]PETSC ERROR: [27]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[35]PETSC ERROR: [4]PETSC ERROR: [34]PETSC ERROR: [13]PETSC ERROR: [42]PETSC ERROR: [6]PETSC ERROR: [48]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[49]PETSC ERROR: [14]PETSC ERROR: [50]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[51]PETSC ERROR: [15]PETSC ERROR: [56]PETSC ERROR: [20]PETSC ERROR: [58]PETSC ERROR: [5]PETSC ERROR: [57]PETSC ERROR: [21]PETSC ERROR: [59]PETSC ERROR:       INSTEAD the line number of the start of the function
[23]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[28]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[29]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[22]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[12]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[37]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[36]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[30]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[7]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[38]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[45]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[44]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[31]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[39]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[46]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[4]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[52]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[53]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[54]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[47]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[55]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[60]PETSC ERROR: [0]PETSC ERROR: [62]PETSC ERROR: [1]PETSC ERROR: [61]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[63]PETSC ERROR: [2]PETSC ERROR: [13]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[6]PETSC ERROR: [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[8]PETSC ERROR:       INSTEAD the line number of the start of the function
[9]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[10]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[14]PETSC ERROR: [11]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR:       INSTEAD the line number of the start of the function
[16]PETSC ERROR: [15]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[17]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[18]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[20]PETSC ERROR: [19]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[24]PETSC ERROR: [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[32]PETSC ERROR: [21]PETSC ERROR: [25]PETSC ERROR:       is given.
[26]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[33]PETSC ERROR: [23]PETSC ERROR: [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[41]PETSC ERROR: [28]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[40]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[35]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[42]PETSC ERROR:       INSTEAD the line number of the start of the function
[34]PETSC ERROR:       INSTEAD the line number of the start of the function
[3]PETSC ERROR: [29]PETSC ERROR: [48]PETSC ERROR: [22]PETSC ERROR: [49]PETSC ERROR: [12]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[37]PETSC ERROR: [50]PETSC ERROR: [36]PETSC ERROR: [51]PETSC ERROR:       INSTEAD the line number of the start of the function
[30]PETSC ERROR: [56]PETSC ERROR: [7]PETSC ERROR: [0]PETSC ERROR:       INSTEAD the line number of the start of the function
[58]PETSC ERROR: [38]PETSC ERROR: [57]PETSC ERROR: [45]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[44]PETSC ERROR: [59]PETSC ERROR:       INSTEAD the line number of the start of the function
[31]PETSC ERROR: [8]PETSC ERROR:       is given.
[9]PETSC ERROR: [39]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[46]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[10]PETSC ERROR: [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[52]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[53]PETSC ERROR:       INSTEAD the line number of the start of the function
[54]PETSC ERROR: [11]PETSC ERROR:       INSTEAD the line number of the start of the function
[1]PETSC ERROR: [47]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[55]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[60]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[62]PETSC ERROR: [16]PETSC ERROR: [61]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[63]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[13]PETSC ERROR:       INSTEAD the line number of the start of the function
[6]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[17]PETSC ERROR:       is given.
[18]PETSC ERROR: [14]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
      is given.
      is given.
[19]PETSC ERROR:       INSTEAD the line number of the start of the function
[24]PETSC ERROR: [20]PETSC ERROR:       INSTEAD the line number of the start of the function
[5]PETSC ERROR: [32]PETSC ERROR:       INSTEAD the line number of the start of the function
[25]PETSC ERROR:       INSTEAD the line number of the start of the function
[21]PETSC ERROR: [26]PETSC ERROR: [4] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[33]PETSC ERROR:       INSTEAD the line number of the start of the function
[2]PETSC ERROR:       INSTEAD the line number of the start of the function
[41]PETSC ERROR: [23]PETSC ERROR:       INSTEAD the line number of the start of the function
      is given.
[28]PETSC ERROR: [40]PETSC ERROR:       INSTEAD the line number of the start of the function
[35]PETSC ERROR:       INSTEAD the line number of the start of the function
[27]PETSC ERROR:       INSTEAD the line number of the start of the function
[3]PETSC ERROR:       is given.
[48]PETSC ERROR:       is given.
[49]PETSC ERROR: [29]PETSC ERROR:       INSTEAD the line number of the start of the function
[22]PETSC ERROR: [50]PETSC ERROR: [12]PETSC ERROR: [51]PETSC ERROR: [37]PETSC ERROR:       INSTEAD the line number of the start of the function
[36]PETSC ERROR: [56]PETSC ERROR:       is given.
[0]PETSC ERROR: [30]PETSC ERROR: [58]PETSC ERROR: [7]PETSC ERROR: [57]PETSC ERROR:       is given.
[38]PETSC ERROR: [59]PETSC ERROR: [45]PETSC ERROR:       INSTEAD the line number of the start of the function
[44]PETSC ERROR: [8]PETSC ERROR:       is given.
[9]PETSC ERROR: [31]PETSC ERROR:       INSTEAD the line number of the start of the function
[5] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[39]PETSC ERROR: [10]PETSC ERROR: [46]PETSC ERROR:       INSTEAD the line number of the start of the function
      is given.
[4]PETSC ERROR:       is given.
[52]PETSC ERROR:       INSTEAD the line number of the start of the function
[53]PETSC ERROR: [11]PETSC ERROR:       is given.
[1]PETSC ERROR: [54]PETSC ERROR:       INSTEAD the line number of the start of the function
      is given.
[47]PETSC ERROR:       INSTEAD the line number of the start of the function
[55]PETSC ERROR: [16]PETSC ERROR: [60]PETSC ERROR:       INSTEAD the line number of the start of the function
[62]PETSC ERROR:       INSTEAD the line number of the start of the function
[61]PETSC ERROR:       is given.
[63]PETSC ERROR:       INSTEAD the line number of the start of the function
[6]PETSC ERROR: [17]PETSC ERROR:       is given.
      is given.
[12] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[18]PETSC ERROR:       is given.
      is given.
[0] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[14]PETSC ERROR:       INSTEAD the line number of the start of the function
      is given.
[7] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[19]PETSC ERROR: [15]PETSC ERROR:       INSTEAD the line number of the start of the function
      is given.
[24]PETSC ERROR:       is given.
      is given.
      is given.
      is given.
[20]PETSC ERROR: [32]PETSC ERROR:       is given.
[25]PETSC ERROR: [5]PETSC ERROR:       is given.
      is given.
[26]PETSC ERROR:       is given.
[33]PETSC ERROR: [21]PETSC ERROR: [2]PETSC ERROR: [4] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[41]PETSC ERROR:       is given.
      is given.
      is given.
[1] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[23]PETSC ERROR: [40]PETSC ERROR:       is given.
[35]PETSC ERROR: [28]PETSC ERROR: [27]PETSC ERROR:       is given.
      is given.
      is given.
[42]PETSC ERROR:       is given.
[34]PETSC ERROR:       is given.
[49]PETSC ERROR: [13] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[6] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[50]PETSC ERROR: [29]PETSC ERROR: [51]PETSC ERROR: [22]PETSC ERROR:       is given.
[12]PETSC ERROR: [56]PETSC ERROR: [37]PETSC ERROR: [0]PETSC ERROR: [36]PETSC ERROR: [58]PETSC ERROR: [14] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[57]PETSC ERROR: [30]PETSC ERROR:       is given.
[7]PETSC ERROR: [59]PETSC ERROR: [15] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[38]PETSC ERROR: [8]PETSC ERROR: [45]PETSC ERROR: [9]PETSC ERROR: [44]PETSC ERROR:       is given.
[20] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[31]PETSC ERROR: [10]PETSC ERROR: [5] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
      is given.
[39]PETSC ERROR:       is given.
[46]PETSC ERROR: [2] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[21] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[4]PETSC ERROR: [11]PETSC ERROR: [52]PETSC ERROR: [1]PETSC ERROR: [53]PETSC ERROR:       is given.
[23] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[54]PETSC ERROR:       is given.
[28] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[16]PETSC ERROR: [47]PETSC ERROR:       is given.
[55]PETSC ERROR:       is given.
[60]PETSC ERROR: [3] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[62]PETSC ERROR:       is given.
[63]PETSC ERROR: [17]PETSC ERROR: [13]PETSC ERROR:       is given.
[6]PETSC ERROR:       is given.
[29] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[18]PETSC ERROR: [22] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[12] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[0] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[37] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[36] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[14]PETSC ERROR: [19]PETSC ERROR: [30] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
      is given.
[7] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[24]PETSC ERROR: [15]PETSC ERROR: [8] VecSet line 492 src/vec/vec/interface/rvector.c
[38] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[9] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[45] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[32]PETSC ERROR: [44] VecSet line 492 src/vec/vec/interface/rvector.c
[25]PETSC ERROR: [20]PETSC ERROR: [10] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[31] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[26]PETSC ERROR: [5]PETSC ERROR: [33]PETSC ERROR: [39] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[2]PETSC ERROR: [46] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[41]PETSC ERROR: [21]PETSC ERROR: [11] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[1] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[52] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[40]PETSC ERROR: [53] VecSet line 492 src/vec/vec/interface/rvector.c
[35]PETSC ERROR: [23]PETSC ERROR: [27]PETSC ERROR: [54] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[16] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[28]PETSC ERROR: [42]PETSC ERROR: [47] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[34]PETSC ERROR: [55] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[3]PETSC ERROR: [60] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[48]PETSC ERROR: [62] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[49]PETSC ERROR: [61] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[17] VecSet line 492 src/vec/vec/interface/rvector.c
[63] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[50]PETSC ERROR: [13] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[51]PETSC ERROR: [6] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[18] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[29]PETSC ERROR: [56]PETSC ERROR: [22]PETSC ERROR: [0]PETSC ERROR: [12]PETSC ERROR: [58]PETSC ERROR: [37]PETSC ERROR: [57]PETSC ERROR: [36]PETSC ERROR: [19] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[14] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[59]PETSC ERROR: [30]PETSC ERROR: [24] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[7]PETSC ERROR: [8]PETSC ERROR: [15] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[9]PETSC ERROR: [38]PETSC ERROR: [32] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[45]PETSC ERROR: [25] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[44]PETSC ERROR: [10]PETSC ERROR: [20] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[26] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[31]PETSC ERROR: [33] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[2] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[39]PETSC ERROR: [41] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[46]PETSC ERROR: [11]PETSC ERROR: [21] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[1]PETSC ERROR: [4]PETSC ERROR: [40] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[52]PETSC ERROR: [35] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[53]PETSC ERROR: [27] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[23] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[16]PETSC ERROR: [54]PETSC ERROR: [42] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[28] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[34] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[47]PETSC ERROR: [3] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[55]PETSC ERROR: [48] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[60]PETSC ERROR: [49] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[62]PETSC ERROR: [17]PETSC ERROR: [61]PETSC ERROR: [50] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[63]PETSC ERROR: [51] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[13]PETSC ERROR: [18]PETSC ERROR: [6]PETSC ERROR: [56] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[29] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[22] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[58] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[57] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[37] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[19]PETSC ERROR: [36] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[59] MatLUFactorNumeric_SuperLU line 121 src/mat/impls/aij/seq/superlu/superlu.c
[14]PETSC ERROR: [24]PETSC ERROR: [30] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[9] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[15]PETSC ERROR: [32]PETSC ERROR: [38] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[25]PETSC ERROR: [45] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[10] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[26]PETSC ERROR: [20]PETSC ERROR: [33]PETSC ERROR: [31] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[2]PETSC ERROR: [5]PETSC ERROR: [41]PETSC ERROR: [39] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[11] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[46] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[21]PETSC ERROR: [40]PETSC ERROR: Signal received!
[35]PETSC ERROR: [52] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[27]PETSC ERROR: --------------------- Error Message ------------------------------------
[16] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[23]PETSC ERROR: [42]PETSC ERROR: [54] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[34]PETSC ERROR: [28]PETSC ERROR: [3]PETSC ERROR: [47] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[48]PETSC ERROR: [55] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[49]PETSC ERROR: [60] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[62] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[50]PETSC ERROR: [61] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[51]PETSC ERROR: [63] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[18] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[56]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: [29]PETSC ERROR: [58]PETSC ERROR: [22]PETSC ERROR: [57]PETSC ERROR: [12]PETSC ERROR: [19] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[37]PETSC ERROR: [59]PETSC ERROR: [36]PETSC ERROR: [24] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[8]PETSC ERROR: [30]PETSC ERROR: [9]PETSC ERROR: [7]PETSC ERROR: [32] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[25] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[38]PETSC ERROR: [10]PETSC ERROR: [45]PETSC ERROR: [26] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[44]PETSC ERROR: [33] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[31]PETSC ERROR: [41] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
Signal received!
[11]PETSC ERROR: [39]PETSC ERROR: [1]PETSC ERROR: [46]PETSC ERROR: [40] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[35] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[4]PETSC ERROR: [27] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[52]PETSC ERROR: [16]PETSC ERROR: [53]PETSC ERROR: [42] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[34] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[54]PETSC ERROR: --------------------- Error Message ------------------------------------
[48] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[47]PETSC ERROR: [49] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[55]PETSC ERROR: [17]PETSC ERROR: [60]PETSC ERROR: [50] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[62]PETSC ERROR: [51] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[61]PETSC ERROR: [18]PETSC ERROR: [63]PETSC ERROR: [56] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[13]PETSC ERROR: Signal received!
[6]PETSC ERROR: [58] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[57] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[19]PETSC ERROR: Signal received!
[59] MatLUFactorNumeric line 2575 src/mat/interface/matrix.c
[24]PETSC ERROR: --------------------- Error Message ------------------------------------
Signal received!
[14]PETSC ERROR: --------------------- Error Message ------------------------------------
[32]PETSC ERROR: Signal received!
[25]PETSC ERROR: [15]PETSC ERROR: --------------------- Error Message ------------------------------------
[26]PETSC ERROR: --------------------- Error Message ------------------------------------
[33]PETSC ERROR: Signal received!
[2]PETSC ERROR: [20]PETSC ERROR: [41]PETSC ERROR: --------------------- Error Message ------------------------------------
[5]PETSC ERROR: Signal received!
[40]PETSC ERROR: --------------------- Error Message ------------------------------------
[35]PETSC ERROR: [21]PETSC ERROR: [27]PETSC ERROR: ------------------------------------------------------------------------
[42]PETSC ERROR: Signal received!
[34]PETSC ERROR: [23]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message ------------------------------------
[48]PETSC ERROR: [28]PETSC ERROR: [49]PETSC ERROR: --------------------- Error Message ------------------------------------
Signal received!
[50]PETSC ERROR: --------------------- Error Message ------------------------------------
[51]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[58]PETSC ERROR: Signal received!
[57]PETSC ERROR: [29]PETSC ERROR: --------------------- Error Message ------------------------------------
[22]PETSC ERROR: [59]PETSC ERROR: [12]PETSC ERROR: --------------------- Error Message ------------------------------------
[37]PETSC ERROR: [8]PETSC ERROR: [36]PETSC ERROR: [9]PETSC ERROR: Signal received!
[30]PETSC ERROR: --------------------- Error Message ------------------------------------
[7]PETSC ERROR: [10]PETSC ERROR: Signal received!
[38]PETSC ERROR: --------------------- Error Message ------------------------------------
[45]PETSC ERROR: Signal received!
[44]PETSC ERROR: --------------------- Error Message ------------------------------------
Signal received!
[11]PETSC ERROR: [31]PETSC ERROR: [1]PETSC ERROR: ------------------------------------------------------------------------
[39]PETSC ERROR: --------------------- Error Message ------------------------------------
[46]PETSC ERROR: --------------------- Error Message ------------------------------------
Signal received!
[16]PETSC ERROR: [4]PETSC ERROR: --------------------- Error Message ------------------------------------
[52]PETSC ERROR: --------------------- Error Message ------------------------------------
[53]PETSC ERROR: Signal received!
Signal received!
Signal received!
[17]PETSC ERROR: [47]PETSC ERROR: --------------------- Error Message ------------------------------------
[55]PETSC ERROR: --------------------- Error Message ------------------------------------
[60]PETSC ERROR: [18]PETSC ERROR: [62]PETSC ERROR: --------------------- Error Message ------------------------------------
[63]PETSC ERROR: --------------------- Error Message ------------------------------------
[13]PETSC ERROR: --------------------- Error Message ------------------------------------
[6]PETSC ERROR: [19]PETSC ERROR: Signal received!
Signal received!
[24]PETSC ERROR: ------------------------------------------------------------------------
Signal received!
Signal received!
Signal received!
[32]PETSC ERROR: [14]PETSC ERROR: [25]PETSC ERROR: Signal received!
Signal received!
[26]PETSC ERROR: [15]PETSC ERROR: [33]PETSC ERROR: Signal received!
[2]PETSC ERROR: Signal received!
[41]PETSC ERROR: ------------------------------------------------------------------------
Signal received!
[20]PETSC ERROR: ------------------------------------------------------------------------
Signal received!
[40]PETSC ERROR: [5]PETSC ERROR: [35]PETSC ERROR: Signal received!
[27]PETSC ERROR: Signal received!
Signal received!
[21]PETSC ERROR: [42]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[34]PETSC ERROR: Signal received!
[48]PETSC ERROR: [23]PETSC ERROR: [49]PETSC ERROR: Signal received!
[28]PETSC ERROR: [50]PETSC ERROR: Signal received!
[51]PETSC ERROR: Signal received!
Signal received!
Signal received!
[56]PETSC ERROR: Signal received!
[57]PETSC ERROR: ------------------------------------------------------------------------
Signal received!
[59]PETSC ERROR: [29]PETSC ERROR: Signal received!
[22]PETSC ERROR: [8]PETSC ERROR: [12]PETSC ERROR: [9]PETSC ERROR: [37]PETSC ERROR: Signal received!
[36]PETSC ERROR: Signal received!
[10]PETSC ERROR: [30]PETSC ERROR: Signal received!
[7]PETSC ERROR: Signal received!
[38]PETSC ERROR: Signal received!
[45]PETSC ERROR: [11]PETSC ERROR: [44]PETSC ERROR: [1]PETSC ERROR: ------------------------------------------------------------------------
Signal received!
[31]PETSC ERROR: Signal received!
Signal received!
[39]PETSC ERROR: [16]PETSC ERROR: [46]PETSC ERROR: Signal received!
Signal received!
[4]PETSC ERROR: ------------------------------------------------------------------------
[52]PETSC ERROR: Signal received!
[17]PETSC ERROR: [54]PETSC ERROR: Signal received!
Signal received!
[47]PETSC ERROR: [18]PETSC ERROR: [55]PETSC ERROR: Signal received!
[60]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[62]PETSC ERROR: Signal received!
[61]PETSC ERROR: Signal received!
[63]PETSC ERROR: [19]PETSC ERROR: [13]PETSC ERROR: Signal received!
[6]PETSC ERROR: [24]PETSC ERROR: ------------------------------------------------------------------------
[32]PETSC ERROR: ------------------------------------------------------------------------
[25]PETSC ERROR: ------------------------------------------------------------------------
[14]PETSC ERROR: [26]PETSC ERROR: ------------------------------------------------------------------------
[33]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[2]PETSC ERROR: [15]PETSC ERROR: [41]PETSC ERROR: ------------------------------------------------------------------------
[40]PETSC ERROR: [20]PETSC ERROR: [35]PETSC ERROR: ------------------------------------------------------------------------
[27]PETSC ERROR: [5]PETSC ERROR: ------------------------------------------------------------------------
[42]PETSC ERROR: ------------------------------------------------------------------------
[34]PETSC ERROR: [21]PETSC ERROR: [3]PETSC ERROR: See docs/changes/index.html for recent updates.
[48]PETSC ERROR: ------------------------------------------------------------------------
[49]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[23]PETSC ERROR: [50]PETSC ERROR: ------------------------------------------------------------------------
[51]PETSC ERROR: [28]PETSC ERROR: ------------------------------------------------------------------------
[56]PETSC ERROR: ------------------------------------------------------------------------
[58]PETSC ERROR: ------------------------------------------------------------------------
[59]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[8]PETSC ERROR: [29]PETSC ERROR: [9]PETSC ERROR: [22]PETSC ERROR: ------------------------------------------------------------------------
[12]PETSC ERROR: ------------------------------------------------------------------------
[37]PETSC ERROR: [10]PETSC ERROR: [36]PETSC ERROR: ------------------------------------------------------------------------
[30]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[7]PETSC ERROR: ------------------------------------------------------------------------
[11]PETSC ERROR: [38]PETSC ERROR: [1]PETSC ERROR: [45]PETSC ERROR: ------------------------------------------------------------------------
[44]PETSC ERROR: ------------------------------------------------------------------------
[31]PETSC ERROR: [16]PETSC ERROR: See docs/changes/index.html for recent updates.
[39]PETSC ERROR: ------------------------------------------------------------------------
[46]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[52]PETSC ERROR: [17]PETSC ERROR: [53]PETSC ERROR: ------------------------------------------------------------------------
[54]PETSC ERROR: [18]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[47]PETSC ERROR: See docs/changes/index.html for recent updates.
[62]PETSC ERROR: [19]PETSC ERROR: [61]PETSC ERROR: ------------------------------------------------------------------------
[63]PETSC ERROR: [24]PETSC ERROR: [13]PETSC ERROR: See docs/changes/index.html for recent updates.
[6]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[32]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[25]PETSC ERROR: See docs/changes/index.html for recent updates.
[26]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[33]PETSC ERROR: [14]PETSC ERROR: [2]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[41]PETSC ERROR: See docs/changes/index.html for recent updates.
[15]PETSC ERROR: See docs/changes/index.html for recent updates.
[40]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[35]PETSC ERROR: See docs/changes/index.html for recent updates.
[27]PETSC ERROR: [20]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[42]PETSC ERROR: [5]PETSC ERROR: [34]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[3]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[48]PETSC ERROR: [21]PETSC ERROR: [49]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[50]PETSC ERROR: See docs/changes/index.html for recent updates.
[51]PETSC ERROR: [23]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[56]PETSC ERROR: [28]PETSC ERROR: [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[58]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[57]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[8]PETSC ERROR: See docs/changes/index.html for recent updates.
[9]PETSC ERROR: See docs/changes/index.html for recent updates.
[29]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[22]PETSC ERROR: [10]PETSC ERROR: [12]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[37]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[36]PETSC ERROR: See docs/changes/index.html for recent updates.
[30]PETSC ERROR: [11]PETSC ERROR: [7]PETSC ERROR: [1]PETSC ERROR: See docs/changes/index.html for recent updates.
[38]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[45]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[44]PETSC ERROR: [16]PETSC ERROR: See docs/changes/index.html for recent updates.
[31]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[39]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[17]PETSC ERROR: [4]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[52]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[53]PETSC ERROR: [18]PETSC ERROR: See docs/changes/index.html for recent updates.
[54]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[47]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[55]PETSC ERROR: [19]PETSC ERROR: [60]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37 CST 2010
[62]PETSC ERROR: [24]PETSC ERROR: [61]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[63]PETSC ERROR: See docs/changes/index.html for recent updates.
[13]PETSC ERROR: [32]PETSC ERROR: [6]PETSC ERROR: [25]PETSC ERROR: See docs/changes/index.html for recent updates.
[26]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[33]PETSC ERROR: See docs/changes/index.html for recent updates.
[2]PETSC ERROR: See docs/changes/index.html for recent updates.
[41]PETSC ERROR: [14]PETSC ERROR: See docs/changes/index.html for recent updates.
[40]PETSC ERROR: [15]PETSC ERROR: [35]PETSC ERROR: See docs/changes/index.html for recent updates.
[27]PETSC ERROR: See docs/changes/index.html for recent updates.
[42]PETSC ERROR: [20]PETSC ERROR: [34]PETSC ERROR: See docs/changes/index.html for recent updates.
[3]PETSC ERROR: [5]PETSC ERROR: [48]PETSC ERROR: See docs/changes/index.html for recent updates.
[49]PETSC ERROR: See docs/changes/index.html for recent updates.
[21]PETSC ERROR: [50]PETSC ERROR: See docs/index.html for manual pages.
[51]PETSC ERROR: See docs/changes/index.html for recent updates.
[56]PETSC ERROR: [23]PETSC ERROR: [0]PETSC ERROR: See docs/changes/index.html for recent updates.
[58]PETSC ERROR: [28]PETSC ERROR: [57]PETSC ERROR: See docs/changes/index.html for recent updates.
[59]PETSC ERROR: See docs/changes/index.html for recent updates.
[10]PETSC ERROR: [29]PETSC ERROR: See docs/changes/index.html for recent updates.
[22]PETSC ERROR: See docs/changes/index.html for recent updates.
[12]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[37]PETSC ERROR: See docs/changes/index.html for recent updates.
[36]PETSC ERROR: [11]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: [30]PETSC ERROR: See docs/changes/index.html for recent updates.
[7]PETSC ERROR: See docs/changes/index.html for recent updates.
[38]PETSC ERROR: [16]PETSC ERROR: [45]PETSC ERROR: See docs/changes/index.html for recent updates.
[44]PETSC ERROR: See docs/changes/index.html for recent updates.
[31]PETSC ERROR: See docs/changes/index.html for recent updates.
[39]PETSC ERROR: [17]PETSC ERROR: [46]PETSC ERROR: See docs/changes/index.html for recent updates.
[4]PETSC ERROR: [18]PETSC ERROR: [52]PETSC ERROR: See docs/changes/index.html for recent updates.
[53]PETSC ERROR: See docs/index.html for manual pages.
[54]PETSC ERROR: See docs/changes/index.html for recent updates.
[19]PETSC ERROR: [47]PETSC ERROR: See docs/changes/index.html for recent updates.
[55]PETSC ERROR: [24]PETSC ERROR: [60]PETSC ERROR: See docs/index.html for manual pages.
[62]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[61]PETSC ERROR: [32]PETSC ERROR: [63]PETSC ERROR: [25]PETSC ERROR: [13]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[6]PETSC ERROR: [26]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[33]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[2]PETSC ERROR: See docs/index.html for manual pages.
[41]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[14]PETSC ERROR: [40]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[35]PETSC ERROR: See docs/index.html for manual pages.
[27]PETSC ERROR: [15]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[42]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[34]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR: [20]PETSC ERROR: [48]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[49]PETSC ERROR: [5]PETSC ERROR: See docs/index.html for manual pages.
[50]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[51]PETSC ERROR: [21]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[56]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[58]PETSC ERROR: [23]PETSC ERROR: [57]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[28]PETSC ERROR: [59]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[8]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[9]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[10]PETSC ERROR: See docs/index.html for manual pages.
[29]PETSC ERROR: See docs/index.html for manual pages.
[22]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[12]PETSC ERROR: [11]PETSC ERROR: [37]PETSC ERROR: [1]PETSC ERROR: [36]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[30]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[7]PETSC ERROR: [16]PETSC ERROR: See docs/index.html for manual pages.
[38]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[45]PETSC ERROR: See docs/index.html for manual pages.
[44]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[31]PETSC ERROR: [17]PETSC ERROR: ------------------------------------------------------------------------
[39]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[46]PETSC ERROR: [18]PETSC ERROR: See docs/index.html for manual pages.
[52]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[53]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[19]PETSC ERROR: [54]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[24]PETSC ERROR: [47]PETSC ERROR: ------------------------------------------------------------------------
[55]PETSC ERROR: See docs/index.html for manual pages.
[60]PETSC ERROR: [32]PETSC ERROR: [62]PETSC ERROR: [25]PETSC ERROR: [61]PETSC ERROR: See docs/index.html for manual pages.
[63]PETSC ERROR: [26]PETSC ERROR: [13]PETSC ERROR: [33]PETSC ERROR: [6]PETSC ERROR: [2]PETSC ERROR: See docs/index.html for manual pages.
[41]PETSC ERROR: See docs/index.html for manual pages.
[40]PETSC ERROR: See docs/index.html for manual pages.
[35]PETSC ERROR: [14]PETSC ERROR: [27]PETSC ERROR: See docs/index.html for manual pages.
[42]PETSC ERROR: [15]PETSC ERROR: [34]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR: See docs/index.html for manual pages.
[49]PETSC ERROR: [20]PETSC ERROR: ------------------------------------------------------------------------
[50]PETSC ERROR: [5]PETSC ERROR: [51]PETSC ERROR: See docs/index.html for manual pages.
[56]PETSC ERROR: [21]PETSC ERROR: [0]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[58]PETSC ERROR: See docs/index.html for manual pages.
[23]PETSC ERROR: [59]PETSC ERROR: See docs/index.html for manual pages.
[28]PETSC ERROR: [8]PETSC ERROR: See docs/index.html for manual pages.
[9]PETSC ERROR: See docs/index.html for manual pages.
[29]PETSC ERROR: [11]PETSC ERROR: [22]PETSC ERROR: [1]PETSC ERROR: [12]PETSC ERROR: See docs/index.html for manual pages.
[37]PETSC ERROR: See docs/index.html for manual pages.
[36]PETSC ERROR: See docs/index.html for manual pages.
[16]PETSC ERROR: [30]PETSC ERROR: See docs/index.html for manual pages.
[7]PETSC ERROR: See docs/index.html for manual pages.
[38]PETSC ERROR: See docs/index.html for manual pages.
[44]PETSC ERROR: [17]PETSC ERROR: ------------------------------------------------------------------------
[31]PETSC ERROR: See docs/index.html for manual pages.
[18]PETSC ERROR: [39]PETSC ERROR: See docs/index.html for manual pages.
[46]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[4]PETSC ERROR: See docs/index.html for manual pages.
[52]PETSC ERROR: [19]PETSC ERROR: [53]PETSC ERROR: See docs/index.html for manual pages.
[24]PETSC ERROR: [54]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[47]PETSC ERROR: [32]PETSC ERROR: [55]PETSC ERROR: [25]PETSC ERROR: [60]PETSC ERROR: ------------------------------------------------------------------------
[62]PETSC ERROR: [26]PETSC ERROR: [61]PETSC ERROR: [33]PETSC ERROR: [63]PETSC ERROR: [2]PETSC ERROR: [13]PETSC ERROR: [41]PETSC ERROR: [6]PETSC ERROR: ------------------------------------------------------------------------
[40]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[14]PETSC ERROR: [42]PETSC ERROR: ------------------------------------------------------------------------
[34]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[3]PETSC ERROR: [15]PETSC ERROR: [48]PETSC ERROR: ------------------------------------------------------------------------
[49]PETSC ERROR: ------------------------------------------------------------------------
[50]PETSC ERROR: [20]PETSC ERROR: [51]PETSC ERROR: ------------------------------------------------------------------------
[5]PETSC ERROR: [56]PETSC ERROR: ------------------------------------------------------------------------
[58]PETSC ERROR: [21]PETSC ERROR: [57]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[59]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[23]PETSC ERROR: [8]PETSC ERROR: ------------------------------------------------------------------------
[9]PETSC ERROR: [28]PETSC ERROR: ------------------------------------------------------------------------
[10]PETSC ERROR: ------------------------------------------------------------------------
[11]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[1]PETSC ERROR: [29]PETSC ERROR: ------------------------------------------------------------------------
[37]PETSC ERROR: [16]PETSC ERROR: [36]PETSC ERROR: ------------------------------------------------------------------------
[30]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[38]PETSC ERROR: [17]PETSC ERROR: [45]PETSC ERROR: ------------------------------------------------------------------------
[18]PETSC ERROR: [31]PETSC ERROR: ------------------------------------------------------------------------
[46]PETSC ERROR: ------------------------------------------------------------------------
[19]PETSC ERROR: [4]PETSC ERROR: ------------------------------------------------------------------------
[52]PETSC ERROR: [24]PETSC ERROR: [53]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[54]PETSC ERROR: [32]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[25]PETSC ERROR: [47]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[55]PETSC ERROR: [26]PETSC ERROR: [60]PETSC ERROR: [33]PETSC ERROR: [62]PETSC ERROR: [2]PETSC ERROR: [61]PETSC ERROR: [41]PETSC ERROR: [63]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[13]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[6]PETSC ERROR: [40]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[35]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[27]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[42]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[34]PETSC ERROR: [14]PETSC ERROR: [3]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[48]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[49]PETSC ERROR: [15]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[50]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[51]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[20]PETSC ERROR: [56]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[0]PETSC ERROR: [5]PETSC ERROR: [58]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[57]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[21]PETSC ERROR: [59]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[8]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[9]PETSC ERROR: [23]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[28]PETSC ERROR: [10]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NE by Unknown Wed Jan 26 11:03:56 2011
[1]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[29]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[22]PETSC ERROR: [16]PETSC ERROR: [12]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[37]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[36]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[7]PETSC ERROR: [17]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[38]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[45]PETSC ERROR: [18]PETSC ERROR: [44]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[31]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[39]PETSC ERROR: [19]PETSC ERROR: [46]PETSC ERROR: /home/rchen/soft/fixedmesh/bypass2/codefor3.1/./joab on a bgl-ibm-g named R00M0NF by Unknown Wed Jan 26 11:03:56 2011
[24]PETSC ERROR: [4]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[52]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[53]PETSC ERROR: [32]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[25]PETSC ERROR: [54]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[26]PETSC ERROR: [47]PETSC ERROR: [33]PETSC ERROR: [55]PETSC ERROR: [2]PETSC ERROR: [60]PETSC ERROR: [41]PETSC ERROR: [62]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[61]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[63]PETSC ERROR: [40]PETSC ERROR: [13]PETSC ERROR: [35]PETSC ERROR: [6]PETSC ERROR: [27]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[42]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[34]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[3]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[48]PETSC ERROR: [14]PETSC ERROR: [49]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[50]PETSC ERROR: [15]PETSC ERROR: [51]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[56]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[0]PETSC ERROR: [20]PETSC ERROR: [58]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[57]PETSC ERROR: [5]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[59]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[21]PETSC ERROR: [8]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[9]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[23]PETSC ERROR: [10]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[28]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[11]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[16]PETSC ERROR: [29]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[22]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[12]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[37]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[17]PETSC ERROR: [30]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[7]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[18]PETSC ERROR: [38]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[45]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[44]PETSC ERROR: Libraries linked from /home/rchen/soft/petsc-3.1-p7/bgl-ibm-goto-O3_440d/lib
[31]PETSC ERROR: [19]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[39]PETSC ERROR: [24]PETSC ERROR: [46]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[4]PETSC ERROR: [32]PETSC ERROR: [52]PETSC ERROR: [25]PETSC ERROR: [53]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[26]PETSC ERROR: [54]PETSC ERROR: [33]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[2]PETSC ERROR: [47]PETSC ERROR: [41]PETSC ERROR: [55]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[60]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[62]PETSC ERROR: [40]PETSC ERROR: [61]PETSC ERROR: [35]PETSC ERROR: [63]PETSC ERROR: [27]PETSC ERROR: [13]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[6]PETSC ERROR: [42]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[34]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[3]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[48]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[49]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[14]PETSC ERROR: [50]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[51]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[15]PETSC ERROR: [56]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[0]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[58]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[57]PETSC ERROR: [20]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[59]PETSC ERROR: [5]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[8]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[9]PETSC ERROR: [21]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[10]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[23]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[28]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[11]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[1]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[16]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[29]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[22]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[37]PETSC ERROR: [17]PETSC ERROR: [36]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[30]PETSC ERROR: [18]PETSC ERROR: [7]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[38]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[45]PETSC ERROR: Configure run at Sat Dec 25 23:04:15 2010
[44]PETSC ERROR: [19]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[31]PETSC ERROR: [24]PETSC ERROR: ------------------------------------------------------------------------
[39]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[46]PETSC ERROR: [32]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[25]PETSC ERROR: [4]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[52]PETSC ERROR: [26]PETSC ERROR: [53]PETSC ERROR: [33]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[2]PETSC ERROR: [54]PETSC ERROR: [41]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[55]PETSC ERROR: [40]PETSC ERROR: [60]PETSC ERROR: [35]PETSC ERROR: [62]PETSC ERROR: [27]PETSC ERROR: [61]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[63]PETSC ERROR: [42]PETSC ERROR: [13]PETSC ERROR: [34]PETSC ERROR: [6]PETSC ERROR: [3]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[48]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[50]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[51]PETSC ERROR: [14]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[0]PETSC ERROR: [15]PETSC ERROR: [58]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[57]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[59]PETSC ERROR: [20]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[8]PETSC ERROR: [5]PETSC ERROR: [9]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[21]PETSC ERROR: [10]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[23]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[11]PETSC ERROR: [28]PETSC ERROR: [1]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[22]PETSC ERROR: [17]PETSC ERROR: [12]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[37]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[36]PETSC ERROR: [18]PETSC ERROR: ------------------------------------------------------------------------
[30]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[7]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[38]PETSC ERROR: [19]PETSC ERROR: [45]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=4 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=4 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --with-cc=/contrib/bgl/bin/mpxlc --with-cxx=/contrib/bgl/bin/mpxlC --with-fc="/contrib/bgl/bin/mpxlf -qnosave" --with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys --with-blas-lapack-lib="-L/contrib/bgl/lib -llapack440 -L/contrib/bgl/lib -lgoto" --with-is-color-value-type=short --with-shared=0 -COPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -CXXOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" -FOPTFLAGS="-O2 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1" --with-debugging=1 --with-x=0 --with-x11=0 --with-batch=1 --with-memcmp-ok --sizeof-char=1 --sizeof-void-p=4 --sizeof-short=2 --sizeof-int=4 --sizeof-long=4 --sizeof-size-t=4 --sizeof-long-long=8 --sizeof-float=4 --sizeof-double=8 --bits-per-byte=8 --sizeof-MPI-Comm=4 --sizeof-MPI-Fint=4 --have-mpi-long-double=1 -PETSC_ARCH=bgl-ibm-goto-O3_440d --download-superlu=/home/rchen/soft/petsc-3.1-p7/externalpackages/superlu_4.0-March_7_2010.tar.gz --download-superlu_dist=/home/rchen/soft/petsc-3.1-p7/externalpackages/SuperLU_DIST_2.4-hg-v2.tar.gz --download-parmetis=/home/rchen/soft/petsc-3.1-p7/externalpackages/ParMetis-dev-p3.tar.gz --download-scalapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/scalapack.tgz --download-blacs=/home/rchen/soft/petsc-3.1-p7/externalpackages/blacs-dev.tar.gz --download-f-blas-lapack=/home/rchen/soft/petsc-3.1-p7/externalpackages/fblaslapack-3.1.1.tar.gz --download-mumps=/home/rchen/soft/petsc-3.1-p7/externalpackages/MUMPS_4.9.2.tar.gz --download-hypre=/home/rchen/soft/petsc-3.1-p7/externalpackages/hypre-2.6.0b.tar.gz
[44]PETSC ERROR: [24]PETSC ERROR: ------------------------------------------------------------------------
[31]PETSC ERROR: ------------------------------------------------------------------------
[32]PETSC ERROR: [39]PETSC ERROR: [25]PETSC ERROR: [46]PETSC ERROR: ------------------------------------------------------------------------
[26]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 4[33]PETSC ERROR: [52]PETSC ERROR: [2]PETSC ERROR: [53]PETSC ERROR: [41]PETSC ERROR: ------------------------------------------------------------------------
[54]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[40]PETSC ERROR: [47]PETSC ERROR: [35]PETSC ERROR: [55]PETSC ERROR: [27]PETSC ERROR: [60]PETSC ERROR: ------------------------------------------------------------------------
[62]PETSC ERROR: [42]PETSC ERROR: [61]PETSC ERROR: [34]PETSC ERROR: [63]PETSC ERROR: [3]PETSC ERROR: [13]PETSC ERROR: [48]PETSC ERROR: [6]PETSC ERROR: [49]PETSC ERROR: ------------------------------------------------------------------------
[50]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[51]PETSC ERROR: ------------------------------------------------------------------------
[56]PETSC ERROR: [14]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0------------------------------------------------------------------------
[58]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[57]PETSC ERROR: [15]PETSC ERROR: ------------------------------------------------------------------------
[59]PETSC ERROR: ------------------------------------------------------------------------
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 8[20]PETSC ERROR: [9]PETSC ERROR: ------------------------------------------------------------------------
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 5------------------------------------------------------------------------
[10]PETSC ERROR: ------------------------------------------------------------------------
[21]PETSC ERROR: ------------------------------------------------------------------------
[23]PETSC ERROR: [11]PETSC ERROR: ------------------------------------------------------------------------
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1[28]PETSC ERROR: ------------------------------------------------------------------------
[16]PETSC ERROR: ------------------------------------------------------------------------
[29]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 17[22]PETSC ERROR: ------------------------------------------------------------------------
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 12------------------------------------------------------------------------
[37]PETSC ERROR: [18]PETSC ERROR: [36]PETSC ERROR: ------------------------------------------------------------------------
[30]PETSC ERROR: ------------------------------------------------------------------------
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 7[19]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[38]PETSC ERROR: [24]PETSC ERROR: [45]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 44[32]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[25]PETSC ERROR: [31]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[39]PETSC ERROR: [26]PETSC ERROR: [46]PETSC ERROR: [33]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2[52]PETSC ERROR: [41]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 53User provided function() line 0 in unknown directory unknown file
[40]PETSC ERROR: [54]PETSC ERROR: [35]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[27]PETSC ERROR: [47]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[55]PETSC ERROR: [42]PETSC ERROR: [60]PETSC ERROR: [34]PETSC ERROR: [62]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3[61]PETSC ERROR: [48]PETSC ERROR: [63]PETSC ERROR: [49]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 13[50]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 6[51]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[56]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
[57]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 14User provided function() line 0 in unknown directory unknown file
[59]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 15User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 9User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 20User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 10User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 21User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 11application called MPI_Abort(MPI_COMM_WORLD, 59) - process 23User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 28User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 16User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 29User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 22application called MPI_Abort(MPI_COMM_WORLD, 59) - process 18application called MPI_Abort(MPI_COMM_WORLD, 59) - process 37User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 36User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 30User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 38application called MPI_Abort(MPI_COMM_WORLD, 59) - process 19application called MPI_Abort(MPI_COMM_WORLD, 59) - process 45User provided function() line 0 in unknown directory unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 31application called MPI_Abort(MPI_COMM_WORLD, 59) - process 24application called MPI_Abort(MPI_COMM_WORLD, 59) - process 39application called MPI_Abort(MPI_COMM_WORLD, 59) - process 32application called MPI_Abort(MPI_COMM_WORLD, 59) - process 46application called MPI_Abort(MPI_COMM_WORLD, 59) - process 25application called MPI_Abort(MPI_COMM_WORLD, 59) - process 52application called MPI_Abort(MPI_COMM_WORLD, 59) - process 26application called MPI_Abort(MPI_COMM_WORLD, 59) - process 54application called MPI_Abort(MPI_COMM_WORLD, 59) - process 33application called MPI_Abort(MPI_COMM_WORLD, 59) - process 47application called MPI_Abort(MPI_COMM_WORLD, 59) - process 41application called MPI_Abort(MPI_COMM_WORLD, 59) - process 55application called MPI_Abort(MPI_COMM_WORLD, 59) - process 40application called MPI_Abort(MPI_COMM_WORLD, 59) - process 60application called MPI_Abort(MPI_COMM_WORLD, 59) - process 35application called MPI_Abort(MPI_COMM_WORLD, 59) - process 62application called MPI_Abort(MPI_COMM_WORLD, 59) - process 27application called MPI_Abort(MPI_COMM_WORLD, 59) - process 61application called MPI_Abort(MPI_COMM_WORLD, 59) - process 42application called MPI_Abort(MPI_COMM_WORLD, 59) - process 63application called MPI_Abort(MPI_COMM_WORLD, 59) - process 34application called MPI_Abort(MPI_COMM_WORLD, 59) - process 48application called MPI_Abort(MPI_COMM_WORLD, 59) - process 49application called MPI_Abort(MPI_COMM_WORLD, 59) - process 50application called MPI_Abort(MPI_COMM_WORLD, 59) - process 51application called MPI_Abort(MPI_COMM_WORLD, 59) - process 56application called MPI_Abort(MPI_COMM_WORLD, 59) - process 58application called MPI_Abort(MPI_COMM_WORLD, 59) - process 57application called MPI_Abort(MPI_COMM_WORLD, 59) - process 59<Jan 26 11:21:46.337038> BE_MPI (ERROR): The error message in the job record is as follows:
<Jan 26 11:21:46.337210> BE_MPI (ERROR):   "killed by exit(1) on node 71"
<Jan 26 11:21:46.601529> BE_MPI (ERROR): The error message in the job record is as follows:
<Jan 26 11:21:46.601594> BE_MPI (ERROR):   "killed by exit(1) on node 71"
