[petsc-users] Trouble with solving 5x5 system... Ay=x on 2 or more processors
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Tue Jan 18 01:30:43 CST 2011
Gaurish,
I would suggest you spend some time reading the PETSc user's manual
available here:
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manual.pdf
These two lines are incorrect.
ierr = VecCreateMPI(PETSC_COMM_WORLD,m,PETSC_DETERMINE,&x);CHKERRQ(ierr);
ierr = VecCreateMPI(PETSC_COMM_WORLD,m,PETSC_DETERMINE,&y);CHKERRQ(ierr);
The problem, as indicated by Shri, is that you are determining your global
size from your local size.  In the case of a single-process run, these two
are the same.  For any other code, global_size = sum(local_size[]),
corresponding to the local size on each process.  You can verify this by
running with 3 processes, you will see a vector of length 15 instead of 10.
A
On Tue, Jan 18, 2011 at 10:23 AM, Gaurish Telang <gaurish108 at gmail.com>wrote:
> Hmm,,,,,
> Then how come the code worked perfectly on 1 processor?
> Any way here is my code.
> I cant really understand where I went wrong. Possibly with VecCreate(). I
> think when more than one processor is involved I am not using it correctly
> static char help[] = "'*x.\n\
>   -f <input_file> : file to load \n\n";
>   Include "petscmat.h" so that we can use matrices.
>   automatically includes:
>      petscsys.h       - base PETSc routines   petscvec.h    - vectors
>      petscmat.h    - matrices
>      petscis.h     - index sets            petscviewer.h -
> viewers
> #include "petscmat.h"
> #include "petscvec.h"
> #include "petscksp.h"        /* For the iterative solvers */
> //extern PetscErrorCode LowRankUpdate(Mat,Mat,Vec,Vec,Vec,Vec,PetscInt);
> //#include <iostream>
> #include <stdlib.h>
> #include <stdio.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **args)
>   Mat                   U;                /* matrix */
>   PetscViewer           fd;               /* viewer */
>   char                  file[PETSC_MAX_PATH_LEN];     /* input file name */
>   PetscErrorCode        ierr;
>   PetscTruth            flg;
>   Vec                   x,y;
>   PetscInt              i,n,m;
>   PetscScalar           *xx;
>   KSP ksp;
>   PC pc;
>   PetscMPIInt size;
> PetscInt num_iters;
> PetscReal rnorm;
> KSPConvergedReason reason;
>   PetscInitialize(&argc,&args,(char *)0,help);
>      Determine file from which we read the matrix
>   ierr =
> PetscOptionsGetString(PETSC_NULL,"-f",file,PETSC_MAX_PATH_LEN-1,&flg);CHKERRQ(ierr);
>   if (!flg) SETERRQ(1,"Must indicate binary file with the -f option");
>      Open binary file.  Note that we use FILE_MODE_READ to indicate
>      reading from this file.
>   ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&fd);CHKERRQ(ierr);
>   ierr = MatLoad(fd,MATMPIDENSE,&U);CHKERRQ(ierr);
>   ierr = PetscViewerDestroy(fd);CHKERRQ(ierr);
>   ierr = MatGetSize(U,&m,&n);CHKERRQ(ierr);
>  ierr=MatView(U,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>  //ierr=MatView(U,PETSC_VIEWER_DRAW_WORLD);CHKERRQ(ierr);
>  ierr=VecSet(x,1);CHKERRQ(ierr);
> ierr = VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> ierr = KSPCreate(PETSC_COMM_WORLD, &ksp); CHKERRQ(ierr);
>     ierr = KSPSetType(ksp, KSPCGNE); CHKERRQ(ierr);
>     ierr = KSPSetOperators(ksp, U, U, DIFFERENT_NONZERO_PATTERN);
> CHKERRQ(ierr);
>     ierr = KSPSetFromOptions(ksp); CHKERRQ(ierr);
>     ierr = KSPSolve(ksp, x, y); CHKERRQ(ierr);
>     ierr = KSPGetIterationNumber(ksp, &num_iters); CHKERRQ(ierr);
>     ierr = KSPGetResidualNorm(ksp, &rnorm); CHKERRQ(ierr);
>     ierr = KSPGetConvergedReason(ksp, &reason); CHKERRQ(ierr);
>     printf ("KSPGetIterationNumber %i \n ", num_iters);
>     printf("KSPGetResidualNorm %f \n" , rnorm );
>     //        printf("KSPConvergedReason %f \n ",reason);
>  ierr=VecView(y,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>      Free work space.  All PETSc objects should be destroyed when they
>      are no longer needed.
>   ierr = MatDestroy(U);CHKERRQ(ierr);
>   ierr = VecDestroy(x);CHKERRQ(ierr);
>    ierr = VecDestroy(y);CHKERRQ(ierr);
>   ierr = PetscFinalize();CHKERRQ(ierr);
>   return 0;
> On Mon, Jan 17, 2011 at 11:56 PM, Gaurish Telang <gaurish108 at gmail.com>wrote:
>> Hi,
>> I am trying to solve a linear system where Ay=x and A is a 5x5 matrix
>> stored in a binary file called 'square' and x=[1;1;1;1;1]
>> I am trying to display the matrix A, and the vectors x(rhs)  and y(soln)
>> in that order to standard output.
>> On running my code on a single processor the answer returned is accurate.
>> But on using 2 processors I get weird error messages PART of which says
>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Nonconforming object sizes!
>> [1]PETSC ERROR: Mat mat,Vec x: global dim 5 10!
>> Also somehow the vector x gets displayed TWICE when run on two processes.
>> A however gets displayed ONCE (as it should!!)
>> I am attaching the output I get when I run on 1 process and the when I run
>> the same code on 2 processes.
>> please let me know where I could be going wrong.
>> (1)
>> This is what I get on running on ONE process:  (Here system is solved
>> successfully)
>> gaurish108 at gaurish108-laptop:~/Desktop$
>> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec -n 1 ./ex4 -f square
>> 1.5761308167754828e-01 1.4188633862721534e-01 6.5574069915658684e-01
>> 7.5774013057833345e-01 7.0604608801960878e-01
>> 9.7059278176061570e-01 4.2176128262627499e-01 3.5711678574189554e-02
>> 7.4313246812491618e-01 3.1832846377420676e-02
>> 9.5716694824294557e-01 9.1573552518906709e-01 8.4912930586877711e-01
>> 3.9222701953416816e-01 2.7692298496088996e-01
>> 4.8537564872284122e-01 7.9220732955955442e-01 9.3399324775755055e-01
>> 6.5547789017755664e-01 4.6171390631153941e-02
>> 8.0028046888880011e-01 9.5949242639290300e-01 6.7873515485777347e-01
>> 1.7118668781156177e-01 9.7131781235847536e-02
>> Process [0]
>> 1
>> 1
>> 1
>> 1
>> 1
>> KSPGetIterationNumber 5
>>  KSPGetResidualNorm 0.000000
>> Process [0]
>> -0.810214
>> 2.33178
>> -1.31131
>> 1.09323
>> 1.17322
>> This is what I get on running on TWO processes:
>> (2)
>> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec -n 2 ./ex4 -f square
>> Process [0]
>> 1
>> 1
>> 1
>> 1
>> 1
>> Process [1]
>> 1
>> 1
>> 1
>> 1
>> 1
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: Petsc Release Version 3.1.0, Patch 5, Mon Sep 27 11:51:54
>> CDT 2010
>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: Nonconforming object sizes!
>> [0]PETSC ERROR: Mat mat,Vec x: global dim 5 10!
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: ./ex4 on a linux-gnu named gaurish108-laptop by gaurish108
>> Mon Jan 17 23:49:18 2011
>> [1]PETSC ERROR: Libraries linked from
>> /home/gaurish108/Desktop/ResearchMeetings/SUPERPETS/petsc-3.1-p5/linux-gnu-c-debug/lib
>> [1]PETSC ERROR: Configure run at Sat Nov 13 20:34:38 2010
>> [1]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
>> --download-f-blas-lapack=1 --download-mpich=1 --download-superlu_dist=1
>> --download-parmetis=1 --with-superlu_dist=1 --with-parmetis=1
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: MatMultTranspose() line 1947 in src/mat/interface/matrix.c
>> [1]PETSC ERROR: KSPSolve_CGNE() line 103 in
>> src/ksp/ksp/impls/cg/cgne/cgne.c
>> [1]PETSC ERROR: KSPSolve() line 396 in src/ksp/ksp/interface/itfunc.c
>> [1]PETSC ERROR: main() line 78 in src/mat/examples/tutorials/ex4.c
>> application called MPI_Abort(MPI_COMM_WORLD, 60) - process 1[cli_1]:
>> aborting job:
>> [0]0:Return code = 0, signaled with Interrupt
>> [0]1:Return code = 60
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110118/f695b7ac/attachment.htm>
