[petsc-users] Regarding printing to standard output. and possible mistake in the code comments in PetscBinaryWrite.m
Matthew Knepley
knepley at gmail.com
Mon Jan 17 18:43:35 CST 2011
On Mon, Jan 17, 2011 at 6:36 PM, Gaurish Telang <gaurish108 at gmail.com>wrote:
> Thank you that seems to have worked! Just to confirm, I have posted the
> output at the end of this message. I hope this is the way the generic output
> should look like.
> I have still have a few questions though.
> (1)
> So all I need to do, is to specify the location of the correct executable
> mpiexec which is $PETSC_DIR/$PETSC_ARCH/bin/mpiexec
> while running the program, right?
Yes
> The contents of my $PETSC_DIR/$PETSC_ARCH/bin are
> gaurish108 at gaurish108-laptop:~/Desktop/ResearchMeetings/SUPERPETS/petsc-3.1-p5/linux-gnu-c-debug/bin$
> ls
> mpicc mpich2version mpiexec mpif77 mpif90 parkill
> (2)
> Do I need to make any changes in the makefiles of the PETSc programs that I
> have written? And hence recompile my codes by using the "new" mpiexec
mpiexec is only for execution, not compiling or linking.
> I mean, since $PETSC_DIR/$PETSC_ARCH/bin/ also contains mpicc (as seen
> above), I want to be sure that the correct mpicc is being used during
> execution.
> (3) Should I run the mpd daemon before using mpiexec??? On the MPICH2 that
> I had installed prior to my PETSc it required me type "mpd &"
> before program execution.
> But it seems for my PETSc mpiexec I don;t need mpd. But should I type it in
> ?? I mean I am not sure if this affects program performance
The new version of MPICH uses hydra, not mpd, to manage the startup.
Matt
> Sincere thanks,
> Gaurish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110117/a1995b89/attachment.htm>
