[petsc-users] Regarding printing to standard output. and possible mistake in the code comments in PetscBinaryWrite.m
Gaurish Telang
gaurish108 at gmail.com
Mon Jan 17 17:20:19 CST 2011
This is what I get on running mpiexec -n 2 ./ex23 -info
Also, using mpirun in place of mpiexec and using the -info option I get the
exact same output you see below.
As far as the MPI implmentation I am using, I have OpenMPI and MPICH
installed on my laptop.
While installing PETSc there were some external packages required. In the
external packages folder I can see the following softwares:
fblaslapack-3.1.1 mpich2-1.0.8 ParMetis-dev-p3 SuperLU_DIST_2.4-hg-v2
Possibly it is this mpich2 that should be used??
Please let me know what I should do. I am quite new to PETSc.
gaurish108 at gaurish108-laptop:~/Desktop/ResearchMeetings/SUPERPETS/petsc-3.1-p5/src/ksp/ksp/examples/tutorials$
[0] PetscInitialize(): PETSc successfully started: number of processors = 1
[0] PetscGetHostName(): Rejecting domainname, likely is NIS
gaurish108-laptop.(none)
[0] PetscInitialize(): Running on machine: gaurish108-laptop
[0] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374784
max tags = 2147483647
[0] PetscCommDuplicate(): returning tag 2147483647
[0] PetscCommDuplicate(): returning tag 2147483646
[0] PetscCommDuplicate(): returning tag 2147483645
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374784
[0] PetscCommDuplicate(): returning tag 2147483644
[0] MatSetUpPreallocation(): Warning not preallocating matrix storage
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 10 X 10; storage space: 22
unneeded,28 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 3
[0] Mat_CheckInode(): Found 10 nodes out of 10 rows. Not using Inode
routines
-2080374784
[0] PetscCommDuplicate(): returning tag 2147483643
[0] PetscCommDuplicate(): returning tag 2147483642
[0] PetscCommDuplicate(): returning tag 2147483641
[0] PetscCommDuplicate(): returning tag 2147483640
[0] PetscCommDuplicate(): returning tag 2147483639
[0] PetscCommDuplicate(): returning tag 2147483638
[0] PetscCommDuplicate(): returning tag 2147483637
[0] PCSetUp(): Setting up new PC
[0] PetscCommDuplicate(): returning tag 2147483636
[0] PetscCommDuplicate(): returning tag 2147483635
[0] PetscCommDuplicate(): returning tag 2147483634
[0] PetscCommDuplicate(): returning tag 2147483633
[0] PetscCommDuplicate(): returning tag 2147483632
[0] PetscCommDuplicate(): returning tag 2147483631
[0] PetscCommDuplicate(): returning tag 2147483630
[0] PetscCommDuplicate(): returning tag 2147483629
[0] PetscCommDuplicate(): returning tag 2147483628
[0] PetscCommDuplicate(): returning tag 2147483627
[0] PetscCommDuplicate(): returning tag 2147483626
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm
4.50879e-16 is less than relative tolerance 1e-07 times initial right hand
side norm 0.707107 at iteration 5
-2080374784
[0] PetscCommDuplicate(): returning tag 2147483625
KSP Object:
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-07, absolute=1e-50, divergence=10000
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object:
type: jacobi
linear system matrix = precond matrix:
Matrix Object:
type=seqaij, rows=10, cols=10
total: nonzeros=28, allocated nonzeros=50
not using I-node routines
Norm of error < 1.e-12, Iterations 5
[0] PetscFinalize(): PetscFinalize() called
[0] PetscCommDuplicate(): returning tag 2147483624
[0] Petsc_DelViewer(): Deleting viewer data in an MPI_Comm -2080374784
[0] Petsc_DelComm(): Deleting PETSc communicator imbedded in a user MPI_Comm
1140850688
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm -2080374784
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm -2080374784
-2080374784
-2080374784
unneeded,28 used
routines
-2080374784
-2080374784
KSP Object:
type: gmres
PC Object:
type: jacobi
Matrix Object:
1140850688
-2080374784
On Mon, Jan 17, 2011 at 5:46 PM, Gaurish Telang <gaurish108 at gmail.com>wrote:
> Hi.
> I had two questions
> (1)
> I was curious to know why the following happens with the PETSc standard
> output. Having created the executable 'test' when I try to run it with
> mpiexec -n 2 ./test
> the same output is printed to the terminal twice. If I use 3 processors,
> then the same output is printed thrice.
> In short the number of processors = number of times the output from PETSc
> is printed. Could this be a mistake with my PETSc installation???
> For example, consider the code in src/ksp/ksp/examples/tutorials/ex23.c
> After creating ex23 the executable and running it with two processors gives
> the following terminal output:
> mpiexec -n 1 ./ex23
> KSP Object:
> type: gmres
> PC Object:
> type: jacobi
> Matrix Object:
> mpiexec -n 2 ./ex23
> KSP Object:
> type: gmres
> PC Object:
> type: jacobi
> Matrix Object:
> KSP Object:
> type: gmres
> PC Object:
> type: jacobi
> Matrix Object:
> (2)
> Also I was told yesterday on the PETSC users mailing list that the MATLAB m
> file PetscBinaryWrite.m converts a sparse matrix in MATLAB into Petsc Binary
> format.
> The following are the comments in the code near the heading saying that
> it works only for square sparse matrices . But it seems to be working quite
> well for rectangular sparse MATLAB matrices also.
> I have tested this in conjunction with PetscBinaryRead.m also, which reads
> in a Petsc binary file into MATLAB as a sparse matrix.
> Is there something I might have missed or some error that I might be
> making???
> Comments in PetscBinaryWrite.m
> % Writes in PETSc binary file sparse matrices and vectors
> % if the array is multidimensional and dense it is saved
> % as a one dimensional array
> % Only works for square sparse matrices
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110117/951198b4/attachment-0001.htm>
