[petsc-users] [petsc-maint #61421] ksp/examples/tutorials/Ex2.c: good with with-debugging but error without-debugging
Mengda Wu
wumengda at gmail.com
Mon Jan 17 15:43:40 CST 2011
This indeed is caused by a bug in Visual c++ 2005 64bit compiler when using
optimization.
The result is correct after installing the hotfix:
http://support.microsoft.com/kb/976617/
Thanks a lot!
Mengda
On Mon, Jan 17, 2011 at 12:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Compiler bug. Immediately before the call to MatMult() in the code add the
> two lines
> ierr = VecView(u,0);
> ierr = MatView(A,0);
> how large are the two objects? Given the code it is inconceivable that
> suddenly the vector length becomes 57.
> Barry
> On Jan 17, 2011, at 2:43 AM, Mengda Wu wrote:
> > Hi all,
> > I just compiled the debugged and optimized versions of petsc-3.1-p7.
> > Both are successful. I am running on Windows Vista 64bit machine.
> > The C/C++ compiler is cl.exe from visual studio 2005 (64 bit) and no
> FORTRAN
> > compiler is used. BLAS/LAPACK
> > support comes from Intel MKL-10.1.3.028 (under em64t\lib). No MPI is
> used.
> > The debugged petsc was configured with:
> > $ ./config/configure.py --with-cc='cl' --with-fc=0 --with-cxx='cl'
> > --with-mpi=
> > 0
> --with-blas-lapack-lib=[mkl_intel_lp64.lib,mkl_intel_thread.lib,mkl_core.lib
> > ,libiomp5mt.lib] -CFLAGS='-MDd -W3 -Z7' -CXXFLAGS='-MDd -W3 -Z7'
> > The optimized petsc was configured with:
> > --with-mpi=
> > 0 --with-debugging=0
> > d.lib,mkl_core.lib,libiomp5mt.lib] -CFLAGS='-MD -wd4996 -O2'
> -CXXFLAGS='-MD
> > -w
> > d4996 -O2'
> > When I run ksp/examples/tutorials/Ex2.c. The result with debugged petsc
> > is
> > Norm of error 0.000156044 iterations 6
> > However, there are errors with the optimized petsc with the output as
> > follows:
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Nonconforming object sizes!
> > [0]PETSC ERROR: Mat mat,Vec y: global dim 56 57!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 7, Mon Dec 20 14:26:37
> > CST 20
> > 10
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR:
> > D:\Develop\Test\PETSc\petsc-3.1-p7\src\ksp\ksp\examples\tutorial
> > s\ex2.exe on a cygwin-c- named CVBRL-38 by mengda Mon Jan 17 00:35:15
> 2011
> > [0]PETSC ERROR: Libraries linked from
> > /cygdrive/d/Develop/Test/PETSc/petsc-3.1-p
> > 7/cygwin-c-opt/lib
> > [0]PETSC ERROR: Configure run at Sun Jan 16 23:34:25 2011
> > [0]PETSC ERROR: Configure options --with-cc=cl --with-fc=0 --with-cxx=cl
> > --with-
> > mpi=0 --with-debugging=0
> > --with-blas-lapack-lib="[mkl_intel_lp64.lib,mkl_intel_t
> > hread.lib,mkl_core.lib,libiomp5mt.lib]" -CFLAGS="-MD -wd4996 -O2"
> > -CXXFLAGS="-MD
> > -wd4996 -O2" --useThreads=0
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: MatMult() line 1888 in
> > src/mat/interface/D:\Develop\Test\PETSc\P
> > ETSC-~1.1-P\src\mat\INTERF~1\matrix.c
> > [0]PETSC ERROR: main() line 146 in
> > src/ksp/ksp/examples/tutorials/D:\Develop\Tes
> > t\PETSc\PETSC-~1.1-P\src\ksp\ksp\examples\TUTORI~1\ex2.c
> > This application has requested the Runtime to terminate it in an unusual
> > way.
> > Please contact the application's support team for more information.
> > I am wondering what problems may lead to the errors. Please let me know
> > if you need more
> > information.
> > Thanks,
> > Mengda
> > Hi all,
> FORTRAN compiler is used. BLAS/LAPACK
> used.
> --with-mpi=
> > 0
> --with-mpi=
> -CXXFLAGS='-MD -w
> > d4996 -O2'
> petsc is
> follows:
> > [0]PETSC ERROR:
> CST 20
> > 10
> > [0]PETSC ERROR:
> > [0]PETSC ERROR:
> 2011
> > 7/cygwin-c-opt/lib
> --with-
> -CXXFLAGS="-MD
> > [0]PETSC ERROR:
> way.
> know if you need more
> > information.
> > Thanks,
> > Mengda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110117/cf958f8c/attachment.htm>
