[petsc-users] Creating random matrices and doing Least squares in PETSc
Barry Smith
bsmith at mcs.anl.gov
Sun Jan 16 18:27:39 CST 2011
On Jan 16, 2011, at 6:23 PM, Gaurish Telang wrote:
> Hi, this might be a vague question but is it possible to create a random rectangular matrix in PETSc of arbitrary specified dimension? More specifically, I would like the rectangular matrix to be sparse and have 1.14% non-zeros in the matrix.
> If there is no such direct way, is there a way for MATLAB to do this and then possibly output it to a text file so that it could be fed to PETSc?
use $PETSC_DIR/bin/matlab/PetscBinaryWrite.m to save the matrix to a fast binary format then use MatLoad() to load it into PETSc
Barry
> The thing is I want to know how fast PETSc does least squares problems |Ax-b| for matrices A of dimensions like 2683x1274 where A is sparse with about 1.14% non-zeros.
> If you have any kind of timing studies / weblinks describing how fast PETSc does least square problems that would be really helpful.
> Sincere thanks,
> Gaurish.
