[petsc-users] PetscMallocAlign
Ataollah Mesgarnejad a.mesgarnejad at gmail.com
Wed Jan 12 13:59:36 CST 2011
It's not only the case with Vectors it come up again for example when I use VecView,even though I flush and destroy the viewer  :
==3347==
==3347== 18,276 bytes in 1 blocks are possibly lost in loss record 3,420 of 3,439
==3347==    at 0x4A04360: memalign (vg_replace_malloc.c:532)
==3347==    by 0x8AC2AA: PetscMallocAlign(unsigned long, int, char const*, char const*, char const*, void**) (mal.c:30)
==3347==    by 0x8ADBAE: PetscTrMallocDefault(unsigned long, int, char const*, char const*, char const*, void**) (mtr.c:192)
==3347==    by 0x9E4350: VecCreate_MPI_Private(_p_Vec*, PetscTruth, int, double const*) (pbvec.c:187)
==3347==    by 0x9E4A0A: VecCreate_MPI (pbvec.c:232)
==3347==    by 0x9A9F32: VecSetType(_p_Vec*, char const*) (vecreg.c:54)
==3347==    by 0x9FEBA0: VecCreateMPI(ompi_communicator_t*, int, int, _p_Vec**) (vmpicr.c:42)
==3347==    by 0xBC06F2: DACreateNaturalVector(_p_DA*, _p_Vec**) (dadist.c:99)
==3347==    by 0xBC24B8: DAView_VTK(_p_DA*, _p_PetscViewer*) (daview.c:145)
==3347==    by 0xBC3336: DAView(_p_DA*, _p_PetscViewer*) (daview.c:244)
==3347==    by 0x6D612C: WriteOutput(AppCtx*, int) (PFMAT-Init.cpp:312)
==3347==    by 0x6CFE59: main (PFMAT-main.cpp:206)
==3347==
Ata
On Jan 12, 2011, at 1:36 PM, Satish Balay wrote:
> perhaps you are missing a call to VecDestroy() on the vec created by
> DACreateGlobalVector?
> Satish
> On Wed, 12 Jan 2011, Ataollah Mesgarnejad wrote:
>> Dear All,
>> I have a memory leak problem with my program; it eventually exhausts all the memory on my system and program aborts. I was checking memory usage with Valgrind and there is a persistent error that always traces back PetscMallocAlign. Something like:
>> ==2918==
>> ==2918== 18,792 bytes in 2 blocks are possibly lost in loss record 2,256 of 2,257
>> ==2918==    at 0x4A04360: memalign (vg_replace_malloc.c:532)
>> ==2918==    by 0x8AC18A: PetscMallocAlign(unsigned long, int, char const*, char const*, char const*, void**) (mal.c:30)
>> ==2918==    by 0x8ADA8E: PetscTrMallocDefault(unsigned long, int, char const*, char const*, char const*, void**) (mtr.c:192)
>> ==2918==    by 0x9E4230: VecCreate_MPI_Private(_p_Vec*, PetscTruth, int, double const*) (pbvec.c:187)
>> ==2918==    by 0x9E48EA: VecCreate_MPI (pbvec.c:232)
>> ==2918==    by 0x9A9E12: VecSetType(_p_Vec*, char const*) (vecreg.c:54)
>> ==2918==    by 0x9FEA80: VecCreateMPI(ompi_communicator_t*, int, int, _p_Vec**) (vmpicr.c:42)
>> ==2918==    by 0xBBFA6C: DACreateGlobalVector(_p_DA*, _p_Vec**) (dadist.c:42)
>> ==2918==    by 0x6CE34F: main (PFMAT-main.cpp:76)
>> ==2918==
>> I'm wondering if this is related to a some error in my declarations or a  known issue or an issue at all?
>> PS: I get the same kind of error both on my Mac os X 10.6 and Fedora 13.
>> Best,
>> Ata Mesgarnejad
