[petsc-users] PETSc and dense matrices
    Jed Brown
    jed at 59A2.org
    Thu Jan  6 11:55:48 CST 2011
On Thu, Jan 6, 2011 at 09:46, Hamid M. <spam.wax at gmail.com> wrote:
> 1- Can I use PETSc to build/populate my LHS matrix on different nodes
> of a cluster (as opposed to constructing it on a single node and then
> distributing it) ?
You should always do this.
> 2- Are there optimized parallel solvers for dense matrices in PETSc ?
The current implementation uses PLAPACK.
You might also consider using FMM (see
http://barbagroup.bu.edu/Barba_group/PetFMM.html) since explicit storage of
dense matrices cannot scale.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110106/a7c3cbf3/attachment.htm>
