[petsc-users] PetscLogEvent
Gu Shiyuan
gshy2014 at gmail.com
Wed Jan 5 14:43:35 CST 2011
Hi all,
I make up a learning examples but cannot explain the result:
In the following codes, everything inside the stage[1] is between
PetscLogEventBegin() and PetscLogEventEnd(), so I expect the time of the
EVENT_MGSolver should take up 100% percent of the time in this stage. But
log_summary only gives me 97%. Where is the 3%?
PetscLogStagePush(stages[1]);
PetscLogEventBegin(MGSolver,0,0,0,0);
for(l=0;l<100;l++){
///// some functions calls
PetscLogEventEnd(MGSolver,0,0,0,0);
PetscLogStagePop();
-log_summary:
--- Event Stage 2:
MatMult 241600 1.0 3.4837e+01 1.0 1.06e+10 1.0 0.0e+00 0.0e+00
0.0e+00 64 75 0 0 0 65 75 0 0 0 303
MatMultAdd 53200 1.0 2.9537e+00 1.0 6.91e+08 1.0 0.0e+00 0.0e+00
0.0e+00 5 5 0 0 0 6 5 0 0 0 234
MatSolve 35200 1.0 6.0787e-02 1.0 3.01e+06 1.0 0.0e+00 0.0e+00
0.0e+00 0 0 0 0 0 0 0 0 0 0 50
VecDot 272000 1.0 1.6983e+00 1.0 7.64e+08 1.0 0.0e+00 0.0e+00
0.0e+00 3 5 0 0 0 3 5 0 0 0 450
VecNorm 35200 1.0 4.8882e-02 1.0 5.28e+05 1.0 0.0e+00 0.0e+00
0.0e+00 0 0 0 0 0 0 0 0 0 0 11
VecScale 117600 1.0 6.2790e-01 1.0 2.62e+08 1.0 0.0e+00 0.0e+00
0.0e+00 1 2 0 0 0 1 2 0 0 0 417
VecCopy 141600 1.0 1.4639e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 3 0 0 0 0 3 0 0 0 0 0
VecSet 35200 1.0 3.4475e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 35200 1.0 3.4980e-02 1.0 5.63e+05 1.0 0.0e+00 0.0e+00
0.0e+00 0 0 0 0 0 0 0 0 0 0 16
VecAYPX 288400 1.0 3.4488e+00 1.0 8.93e+08 1.0 0.0e+00 0.0e+00
0.0e+00 6 6 0 0 0 6 6 0 0 0 259
VecWAXPY 100800 1.0 1.3907e+00 1.0 3.81e+08 1.0 0.0e+00 0.0e+00
0.0e+00 3 3 0 0 0 3 3 0 0 0 274
VecPointwiseMult 320000 1.0 4.8273e+00 1.0 5.72e+08 1.0 0.0e+00 0.0e+00
0.0e+00 9 4 0 0 0 9 4 0 0 0 119
KSPSolve 17600 1.0 5.6411e-01 1.0 6.14e+06 1.0 0.0e+00 0.0e+00
0.0e+00 1 0 0 0 0 1 0 0 0 0 11
PCApply 35200 1.0 1.2111e-01 1.0 3.01e+06 1.0 0.0e+00 0.0e+00
0.0e+00 0 0 0 0 0 0 0 0 0 0 25
MGSolver 1 1.0 5.3215e+01 1.0 1.41e+10 1.0 0.0e+00 0.0e+00
0.0e+00 97100 0 0 0 100100 0 0 0 265
Moreover,
What are the last four parameters of PetscLogEventBegin() used for? The
manually vaguely states that "objects associated with the event".
The provided examples set them to zeros. In what situation should we pass a
non-zero?
I can obtain profiling information with -log_summary but I get nothing with
-log or -log_all. Did I miss any steps for -log/-log_all to work?
Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110105/1bb31522/attachment-0001.htm>
