[petsc-users] pastix solver break at pastix_checkMatrix
Sun Jan 2 23:10:47 CST 2011
   I just two distinct memory leaks in pastix.c (new file attached) for 3.1 (also fixed in petsc-dev).
   Barry
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110102/0daa964e/attachment-0001.obj>
On Jan 2, 2011, at 9:42 PM, Gong Ding wrote:
> Dear  Barry,
> It seems the patch will cause memory leak.
> when  valOnly is false, memory will be allocated for colptr, row and values.
> 99:  if (!valOnly){
> 100:   ierr = PetscMalloc(((*n)+1) *sizeof(PetscInt)   ,colptr );CHKERRQ(ierr);
> 101:   ierr = PetscMalloc( nnz     *sizeof(PetscInt)   ,row);CHKERRQ(ierr);
> 102:   ierr = PetscMalloc( nnz     *sizeof(PetscScalar),values);CHKERRQ(ierr);
> But at the end of function MatConvertToCSC
> 186:    ierr = PetscMemcpy(*colptr,tmpcolptr,(*n+1)*sizeof(PetscInt));CHKERRQ(ierr);
> 187:    ierr = PetscMalloc(((*colptr)[*n]-1)*sizeof(PetscInt),row);CHKERRQ(ierr);
> 188:   ierr = PetscMemcpy(*row,tmprows,((*colptr)[*n]-1)*sizeof(PetscInt));CHKERRQ(ierr);
> 189:    ierr = PetscMalloc(((*colptr)[*n]-1)*sizeof(PetscScalar),values);CHKERRQ(ierr);
> 190:    ierr = PetscMemcpy(*values,tmpvalues,((*colptr)[*n]-1)*sizeof(PetscScalar));CHKERRQ(ierr);
> memory will be allocated again.
> Which means when code call MatConvertToCSC next time, the memory allocated at line 100-102 will be lost.
> Will you please fix this problem? i.e. check the *colptr, *row and *values, when they are not empty, skip the memory allocation
> at line  100-102.
> Yours
> Gong Ding
