[petsc-users] Multiple Copies of KSP
    Satish Balay
    balay at mcs.anl.gov
    Mon Feb 28 23:12:32 CST 2011
It should work. you'll have to use gdb to determine exact location and
reason for this crash in your code.
satish
On Mon, 28 Feb 2011, Joshua Booth wrote:
> Hello,
> In reply,
> I get a Segment fault even though I only call:
> KSP;
> KSPCreate(MPI_COMM_SELF, &ksp);
> Again... note that this is being done by all cores in the MPI_COMM_WORLD at
> the same time.
> On Mon, Feb 28, 2011 at 11:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Feb 28, 2011, at 10:07 PM, Joshua Booth wrote:
> > > Hello,
> > > I was wondering if it is possible to have multiple KSP running, each on
> > their own core but in the same program.
> >   Yes. If you want a separate linear solve on each MPI process then you use
> > MPI_COMM_SELF for the KSP, note that you also need to use that same
> > MPI_COMM_SELF for creating the Vecs and Mats since each process needs its
> > own for its particular linear system.
> > > When I have tried this before using MPI_COMM_SELF,  I get an error.
> >    We would need more information to determine what has gone wrong.
> >   Barry
> > > Thank you
> > > Joshua Booth
