[petsc-users] Search order for BLAS
Sat Feb 26 19:36:50 CST 2011
On Feb 26, 2011, at 7:03 PM, Jed Brown wrote:
> On Sun, Feb 27, 2011 at 01:56, F R Foust <frfoust at yahoo.com> wrote:
> I was trying to build petsc using MKL blas/lapack and had a small issue.  I tried to point configure at the mkl directory with --with-blas-lapack-dir, but it found an installation of ATLAS already in /usr/local/lib and used that instead.
> Is that where your MKL is? If not, then this should be considered a bug, but it's probably hard to fix because /usr/local/lib must be a system path which is searched automatically.
>  I poked around and found a fixed search order in BuildSystem/config/packages/BlasLapack.py (it tries ATLAS, AMD ACML, then MKL).
> Is there any way to force a specific flavor of BLAS in a flag passed to configure (I mean, so I don't have to modify BlasLapack.py, which is what I did).  Or alternatively, is there a way to force the issue by using --with-blas-lapack-lib, --with-blas-lib?  I wasn't able to figure out the correct incantation to include all of the stuff MKL needs to link against.
> You can find what is necessary here, then put it in --with-blas-lapack-lib.
> http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/
    Very powerful, but why does it only support a tiny number of versions?
   Barry
