[petsc-users] About MatLUFactor()
Golam Rabbani
mgrabbani at gmail.com
Fri Feb 25 19:19:25 CST 2011
Thanks. Although I have never used petsc-dev but the standard version seemed
easy to me( I am new to linux as well)... will let you know once i have
tried it out.
Golam
On Fri, Feb 25, 2011 at 4:43 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Customized MatMatSolve_SeqDense() is added to petsc-dev.
> Hong
> On Fri, Feb 25, 2011 at 11:36 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > A custom MatMatSolve_SeqDense() will work much better than the one that
> does a single solve at a time because it will use Blas 3 unstead of 2.
> > Barry
> > On Feb 25, 2011, at 11:25 AM, Hong Zhang wrote:
> >> Golam:
> >>> Oh, It thought MatMatSolve() was there as you mention something about
> it in
> >>> the FAQ. Please add it then.
> >> Checking carefully, I realize that petsc supports MatMatSolve() for
> >> all matrix types
> >> by calling MatMatSolve_Basic() which calls MatSolve() for each rhs
> vector,
> >> except few matrix types (seqdense is not included) that we provided
> >> more efficient implementation.
> >> A simplified ex1.c with MatMatSolve() for petsc-dev is attached
> >> (note: this only works with petsc-dev)
> >> for your info.
> >> Hong
> >>> Thanks,
> >>> Golam
> >>> On Thu, Feb 24, 2011 at 7:31 PM, Hong Zhang <hzhang at mcs.anl.gov>
> wrote:
> >>>> For sequential dense in-place LU factorization, see
> >>>> /src/mat/examples/tests/ex1.c.
> >>>> For parallel, you need install PLAPACK.
> >>>> It seems we do not have MatMatSolve() for dense matrix format. I can
> >>>> add it if you need it.
> >>>> Hong
> >>>> On Thu, Feb 24, 2011 at 8:43 PM, Golam Rabbani <mgrabbani at gmail.com>
> >>>> wrote:
> >>>>> Hi,
> >>>>> I need to use MatLUFactor(), but do not know what to pass for the
> last 3
> >>>>> arguments. Would you please explain a bit; I did not find any example
> >>>>> code
> >>>>> for this one.
> >>>>> PetscErrorCode MatLUFactor(Mat mat,IS row,IS col,const MatFactorInfo
> >>>>> *info)
> >>>>> My matrix is a dense one and the result from this call will be used
> in
> >>>>> MatMatSolve().
> >>>>> Regards,
> >>>>> Golam
> >> <ex1.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110225/4f01770d/attachment.htm>
