[petsc-users] MatSetValues is expensive
Jed Brown
jed at 59A2.org
Fri Feb 25 10:36:40 CST 2011
On Fri, Feb 25, 2011 at 17:31, M. Scot Breitenfeld <brtnfld at uiuc.edu> wrote:
> I have not because on the machine I'm running on the compilation fails
> with error: cast to type "__m64" is not allowed, I've reported it back
> in September (I'm going to upgrade my compiler and OS soon, so hopefully
> that will fix the problem).
Sounds like a compiler/libraries problem.
That would be great! But I don't see in the manual a function for
> creating a parallel SBAIJ matrix, only a sequential SBAIJ.
See MatCreateMPISBAIJ()
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110225/1be8e33d/attachment.htm>
