[petsc-users] undefined reference error in make test
    Jed Brown
    jed at 59a2.org
    Fri Feb 25 06:25:56 CST 2011
On Fri, Feb 25, 2011 at 12:18, Mohammad Mirzadeh <mirzadeh at gmail.com> wrote:
> Just tried hypre-2.7.0b. That didn't solve the problem either. However, I
> just found this in my make.log file that might help:
> mhyp.c: In function 'MatZeroEntries_HYPREStruct_3d':
> mhyp.c:397: warning: implicit declaration of function
> 'hypre_StructMatrixClearBoxValues'
I just built PETSc with hypre-2.7.0b and it works for me. Are you sure that
you are using the new hypre-2.7.0b instead of stale files from hypre-2.0.0?
You can check that this function is declared in "_hypre_struct_mv.h", and
also check that it is present in the library using
$ nm ompi/lib/libHYPRE.a |grep hypre_StructMatrixClearBoxValues
                 U hypre_StructMatrixClearBoxValues
0000000000004543 T hypre_StructMatrixClearBoxValues
The second line shows that the symbol is defined in that archive.
Background: they intended this to be a private function, but did not provide
a public interface to zero the entries, therefore PETSc calls this private
function which is declared in
#include "_hypre_struct_mv.h"
included via "mhyp.h" from "mhyp.c".
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110225/ea12bb2a/attachment.htm>
