[petsc-users] MatSetValues is expensive
M. Scot Breitenfeld
brtnfld at uiuc.edu
Thu Feb 24 16:49:49 CST 2011
On 02/24/2011 10:20 AM, Jed Brown wrote:
> On Thu, Feb 24, 2011 at 16:33, M. Scot Breitenfeld <brtnfld at uiuc.edu
> <mailto:brtnfld at uiuc.edu>> wrote:
> I'm working on a particle type method and I'm using MatSetValues, to
> insert values (add_values) into my matrix. Currently I:
> do i, loop over number of particles
> do j, loop over particles in i's family
> How big is a typical family?
300- 900 particles
> in row i's dof; insert values in columns of j's (x,y,z) dofs
> (3 calls to MatSetValues for i's x,y,z dof)
> Why make three calls here instead of one?
I split the x-y-z row entries up depending on if the dof is prescribed,
I'll combine them and see if that helps.
> in row j's dof; insert values in columns of i's (x,y,z) dofs
> (3 calls to MatSetValues for j's x,y,z dof)
> Again, why call these separately? Also, is the matrix symmetric?
I split them depending on if the dof of particle j is prescribed. The
matrix is symmetric and the percentage of non-zeros in the matrix has a
range of 3%-7% depending on the number of particles in the family.
> enddo
> enddo
> Running serially, using MatSetValues it takes 294.8 sec. to
> assemble the
> matrix,
> Are you sure that it was preallocated correctly? Is the cost to
> compute the entries essentially zero?
Assuming you preallocate by:
CALL MatCreateMPIAIJ(PETSC_COMM_WORLD, &
3*mctr, 3*mctr, &
total_global_nodes*3, total_global_nodes*3, &
0, d_nnz, 0, o_nnz, A, ierr)
and I tried, as suggested,
CALL MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_TRUE, ierr)
and it does not report any problems.
I would not say it's zero to compute the entries (I guess it takes about
3.5ms per particle for the calculations). This is a fairly small case,
only 8000 particles.
> FEM has a simple quadrature loop that builds a dense element matrix,
> MatSetValues() is called once per element.
That is what I meant, once per element.
I do have a simpler formulation that allows me to enter an entire row
all at once per particle:
... fill the rows of i's dofs (x,y,z)
enddo
call MatSetValues...
enddo
For the same case, it takes 6 seconds to assemble. If I remove the
MatSetValues call it takes 0.66 seconds (for this case the calculations
are REALLY simple), the family is also always smaller then the previous
method.
