[petsc-users] MatSetValues is expensive
Matthew Knepley
knepley at gmail.com
Thu Feb 24 09:55:34 CST 2011
On Thu, Feb 24, 2011 at 9:33 AM, M. Scot Breitenfeld <brtnfld at uiuc.edu>wrote:
> Hi,
> I'm working on a particle type method and I'm using MatSetValues, to
> insert values (add_values) into my matrix. Currently I:
> do i, loop over number of particles
> do j, loop over particles in i's family
> in row i's dof; insert values in columns of j's (x,y,z) dofs
> (3 calls to MatSetValues for i's x,y,z dof)
You can set this whole row with a single call.
> in row j's dof; insert values in columns of i's (x,y,z) dofs
> (3 calls to MatSetValues for j's x,y,z dof)
> enddo
> enddo
> Running serially, using MatSetValues it takes 294.8 sec. to assemble the
> matrix, if I remove the calls to MatSetValues it takes 29.5 sec. to run
> through the same loops, so the MatSetValues calls take up 90% of the
> assembling time. I'm preallocating the A matrix specifying d_nnz and o_nnz.
Its hard to believe that the preallocation is correct. In order to check,
use
MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR)
before your MatSetValues() calls.
> I guess I need to add extra storage so I can call the MatSetValues with
> more values so that I can call it less, or just do a lot of
> recalculating of values so that I can add an entire row at once. I just
Recalculating?
> want to make sure this is expected behavior and not something that I'm
> doing wrong before I start to rewrite my assembling routine. Probably a
> hash table would be better but I don't want to store that and then
> convert that to a CRS matrix, I'm already running into memory issues as
> it is.
> Just out of curiosity, wouldn't a finite element code have a similar
> situation, in that case you would form the local stiffness matrix and
> then insert that into the global stiffness matrix, so you would be
> calling MatSetValues "number of elements" times.
No, you call it once per element matrix.
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110224/90dad69a/attachment.htm>
