[petsc-users] PCDiagonalScale
Jed Brown jed at 59A2.org
Thu Feb 24 05:30:15 CST 2011
On Thu, Feb 24, 2011 at 12:14, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> I'm using FGMRES but apparently it doesn't support diagonal scaling.
GCR also tolerates a variable preconditioner and it does not have such a
check. I don't know if that means it can use diagonal scaling or just that
someone forgot to check, but you could try it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110224/036342c8/attachment.htm>
