[petsc-users] PCDiagonalScale
    Klaij, Christiaan
    C.Klaij at marin.nl
    Thu Feb 24 01:16:07 CST 2011
OK. So if I understand correctly (?) in Fortan all I need is:
call KSPGetPC
call PCDiagonalSet
call KSPSolve
I'm using a MatShell and PCShell but I guess that doesn't matter?
> 3) at line 253 I added :
>      call PCDiagonalScale(pc,PETSC_TRUE,ierr)
This is not the correct interface. You want PCDiagonalScaleSet(pc,X,ierr).
PCDiagonalScale() is a getter with petsc-3.1 and is not available from
Fortran (but you don't need it). The naming has been made consistent in
petsc-dev.
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
