[petsc-users] matrix/vector-library
    Jed Brown
    jed at 59A2.org
    Tue Feb 22 09:49:11 CST 2011
On Tue, Feb 22, 2011 at 16:42, Clemens Domanig
<clemens.domanig at uibk.ac.at>wrote:
> Maybe someone knows a library with commands that are similar to MatLab
> because I have to port hundreds lines of MatLab-code to C++.
>From C++, you might consider a template library like Eigen (
http://eigen.tuxfamily.org). It overloads the usual arithmetic operators and
performance is very good for small sizes. The downside is longer compilation
time than a classic library and confusing error messages if you have type
errors.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110222/61627570/attachment.htm>
