[petsc-users] Least squares: using unpreconditioned LSQR
Shri abhyshr at mcs.anl.gov
Thu Feb 17 21:19:42 CST 2011
Use the option -pc_type none.
----- Original Message -----
I wanted to solve some least squares problems using PETSc. My test matrix is size 3x2 but I wish to use this code for solving large ill-conditioned rectangular systems later.
Looking at the PETSc manual I the found the KSPLSQR routine which implements the LSQR algorithm.
However I am unsure how to use this routine. I am pasting the lines of the code which I use to set up the solver.
Through the terminal I pass the option -ksp_type lsqr while running exectuable.
ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
ierr = KSPSetOperators(ksp,A,PETSC_NULL,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
As you can see I have used PETSC_NULL for the preconditioner matrix since I wish to use the *unpreconditioned* version of the LSQR algorithm. This gives me an error.
If I pass the matrix A it gives me an error again. I am not sure how to tell PETSc not to use a preconditioner.
Could you pease tell me how I should use KSPSetOperators statement in this case to use the unpreconditioned algorithm.
If you have a better sparse matrix least squares algorithm implemented please let me know.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110217/cc7a6d20/attachment.htm>
