[petsc-users] KSPBuildSolution
    Juha Jäykkä
    juhaj at iki.fi
    Thu Feb 17 15:21:43 CST 2011
> Yes, if your BC do not give at least a locally unique solution, then your
> Jacobian will
> be rank deficient and Newton breaks down. You can still try Picard, but I
> recommend
> understanding what you mean by a solution first.
Thanks for confirming. And for the suggestion to try Picard, but it simply
shoots out to somewhere in the direction of Alpha Centauri or some such:
reaches function values in excess of 1.e+34 in less than ten SNES
iterations... Perhaps there is such a solution, but that is certainly not what
I want.
Especially since I think I figured out an alternative boundary condition. But
I do not know how to implement that in PETSc.
How do I require
f'(xmax) = constant_A
f(xmax) = constant_B
and no condition (I could require f(xmin)=0, but that is exactly the non-
condition I discovered) at xmin?
I did not find any examples of how to do this and it does not seem to be
straightforward. Do I need to convert from f, f', f'' to f, g, g' with g=f' to
change the f'(xmax) condition to a Dirichlet one for g? But that does not seem
to be feasible since I can not think of what equation g (or f') should obey in
the interior - recall that I just have a single equation, F(f, f', f'') = 0.
Cheers,
-Juha
		| Juha Jäykkä, juhaj at iki.fi			|
		| http://www.maths.leeds.ac.uk/~juhaj		|
Name: not available
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110217/39719ce8/attachment.pgp>
