[petsc-users] KSPBuildSolution
Juha Jäykkä juhaj at iki.fi
Wed Feb 16 18:11:45 CST 2011
Hi again.
I do not know which one to answer to, but thanks to all. I got one step
further with your help:
[0]PETSC ERROR: Zero pivot row 1 value 1.90611e-13 tolerance 1e-12!
Adding -pc_factor_shift_type POSITIVE_DEFINITE helps and now I get at least
some progress. It does not matter if I use -snes_fd, coloring or my hand-
written Jacobian. If I start from a non-solution initial guess, they all
progress somewhat towards what I believe is more or less a real solution. This
is all ran with -pc_type lu -ksp_type preonly, btw.
However, they do not seem to change the second to the last (counting from left
to right) value on the lattice (this is 1D). It does change, but only by 0.02%
while values elsewhere in the lattice change much more significantly. Again, I
am running with the parameters where I know the exact solution and my initial
guess is, on purpose, 0.01 off the correct one (except at the endpoints). What
could be causing this?
One thing strikes me as odd. I tried checking the value of the function at the
first iteration and at that particular point it is of the order of -1.e-9,
whereas in the next point to the left, it is +1.e-9 and then starts increasing
towards the left before it starts decreasing again around half-way through the
lattice.
Cheers,
Juha
		| Juha Jäykkä, juhaj at iki.fi			|
		| http://www.maths.leeds.ac.uk/~juhaj		|
Name: not available
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110217/a1830ada/attachment.pgp>
