[petsc-users] Trouble understanding -vec_view output.
Matthew Knepley
knepley at gmail.com
Mon Feb 14 11:11:23 CST 2011
On Mon, Feb 14, 2011 at 11:01 AM, Gaurish Telang <gaurish108 at gmail.com>wrote:
> Hi,
> I am having trouble understanding the -vec_view output of the simple code I
> have pasted underneath. In it, I am just reading two PetscBinary files
> created with a stand alone code. one containing a matrix and another
> containing a vector.
> However on doing -vec_view during run-time, I get a sequence of zeros
> before the actual vector of the binary file is printed. But when I read the
> PetscBinary file in MATLAB I get the correct vector.
> Why does this happen? Is it because I am using vector type VECMPI to load
> the binary file (* ierr = VecLoad(fd_b,VECMPI,&b);CHKERRQ(ierr); *)??
> e.g.
> The ASCII text file (BEFORE converting to binary) with standalone code
> looks like
> 4
> 6
> The output I get on -vec_view is
> 0
> 0
> 4
> 6
> But with VecGetSize I get the vector length to be 2. !!!
Send the entire output and input files to petsc-maint at mcs.anl.gov. I
guarantee you that
this is just misunderstanding, but its impossible to see exactly what you
are doing from
this sample. For instance, in parallel -vec_view will print Process [k].
Matt
> Thank you,
> Gaurish
> Code:
> int main(int argc,char **args)
> Mat A ;
> Vec b ;
> PetscTruth flg_A,flg_b ;
> PetscErrorCode ierr ;
> PetscInt m,n,length ;
> char
> file_A[PETSC_MAX_PATH_LEN],file_b[PETSC_MAX_PATH_LEN] ;
> PetscViewer fd_A, fd_b ;
> PetscInitialize(&argc,&args,(char *)0,help);
> /* Get the option typed from the terminal */
> ierr =
> PetscOptionsGetString(PETSC_NULL,"-matrix",file_A,PETSC_MAX_PATH_LEN-1,&flg_A);CHKERRQ(ierr);
> if (!flg_A) SETERRQ(1,"Must indicate binary matrix matrix file with the
> -matrix option");
> ierr =
> PetscOptionsGetString(PETSC_NULL,"-vector",file_b,PETSC_MAX_PATH_LEN-1,&flg_b);CHKERRQ(ierr);
> if (!flg_b) SETERRQ(1,"Must indicate binary matrix matrix file with the
> -vector option");
> /* Load the matrix and vector */
> ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,file_A,FILE_MODE_READ,&fd_A);CHKERRQ(ierr);
> ierr = MatLoad(fd_A,MATMPIAIJ,&A);CHKERRQ(ierr);
> ierr = PetscViewerDestroy(fd_A);CHKERRQ(ierr);
> //ierr=MatView(A,PETSC_VIEWER_DRAW_WORLD);CHKERRQ(ierr);
> ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,file_b,FILE_MODE_READ,&fd_b);CHKERRQ(ierr);
> ierr = PetscViewerDestroy(fd_b);CHKERRQ(ierr);
> /* Simple Cursory checks */
> ierr = MatGetSize(A,&m,&n);CHKERRQ(ierr);
> ierr=PetscPrintf(PETSC_COMM_WORLD,"\n %i %i \n",m,n);CHKERRQ(ierr);
> ierr=VecGetSize(b,&length);CHKERRQ(ierr);
> ierr=PetscPrintf(PETSC_COMM_WORLD,"%i \n",length);CHKERRQ(ierr);
> //ierr=VecView(b,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> /* Destroy Objects. */
> MatDestroy(A);
> VecDestroy(b);
> ierr = PetscFinalize();CHKERRQ(ierr);
> sleep(4);
> return 0;
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110214/c1451f39/attachment.htm>
