[petsc-users] petsc-users Digest, Vol 26, Issue 30
Kontsantinos Kontzialis ckontzialis at lycos.com
Sun Feb 13 20:24:16 CST 2011
On 02/13/2011 08:00 PM, petsc-users-request at mcs.anl.gov wrote:
> Send petsc-users mailing list submissions to
> 	petsc-users at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
>     1. Re:  Guidelines for solving the euler equations with an
>        implicit matrix free approach (Matthew Knepley)
>     2.  Reading vtk file in parallel and assigning to an array
>        (khalid ashraf)
>     3. Re:  Reading vtk file in parallel and assigning to an	array
>        (Matthew Knepley)
> Message: 1
> Date: Sat, 12 Feb 2011 16:12:36 -0600
> From: Matthew Knepley<knepley at gmail.com>
> Subject: Re: [petsc-users] Guidelines for solving the euler equations
> 	with an implicit matrix free approach
> To: PETSc users list<petsc-users at mcs.anl.gov>
> Message-ID:
> 	<AANLkTimus8N2jUu7Bvu0TZe59dr4FTpoJFh+m0QQUN-V at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> On Fri, Feb 11, 2011 at 10:37 AM, Kontsantinos Kontzialis<
> ckontzialis at lycos.com>  wrote:
>> Dear Petsc team,
>>   I'm new in Petsc and I'm trying to solve the euler equations of fluid
>> dynamics
>> using an implicit matrix free approach with a spatial discontinues galerkin
>> discretization.
>> I need some directions about how can I solve the following system:
>> (M/dt+dR/du)*DU=R
>> where R denotes the residual of the system and dR/du the residual jacobian.
>> Please help.
> Petsc provides linear algebra and nonlinear solvers. This is fine once you
> have discretized.
> It sounds like you will use DG:
>    a) on a structured or unstructured grid?
> The PETSc DA supports structured grids in any dimension. After this, you
> want to use the
> TS object to present your system. There are many examples in the TS, e.g.
> ex10 for
> radiation-diffusion or ex14 for hydrostatic ice flow.
> Once you have your problem producing the correct residual and Jacobian, we
> can talk
> about solvers.
>     Matt
>> Kostas
Matt,
Also, I work on unstructured grids in 2d.
Kostas
