[petsc-users] Howto evaluate function on grid
Klaus Zimmermann
klaus.zimmermann at physik.uni-freiburg.de
Tue Feb 8 11:17:43 CST 2011
On 02/08/2011 06:03 PM, Jed Brown wrote:
> On Tue, Feb 8, 2011 at 17:52, Klaus Zimmermann
> <klaus.zimmermann at physik.uni-freiburg.de
> <mailto:klaus.zimmermann at physik.uni-freiburg.de>> wrote:
> I agree. This is mostly because I didn't understand the concepts
> so well at the time I wrote this code and one of the reasons why I
> would like to refactor.
> In my case there should in principle be three output vectors. All
> the facilities I have seen in petsc only deal with a single output
> vector. Is this correct?
> Of course there is an obvious mapping, but I would prefer to keep
> the vectors apart because that way it is easier to deal with the
> parallel layout.
> Packing them together will give you better memory performance. You can
> extract separate pieces with the VecStride functions if you need it
> separate. If you have a really good reason for storing them
> separately, petsc-dev has VecNest which lets you treat several vectors
> as one, but some operations are more expensive and I would not
> recommend using it for your purposes.
Thanks for the info. I guess I'll have them interleaved then and extract
the components for the global calculations afterwards.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110208/3f50f0a9/attachment.htm>
