[petsc-users] questions about the multigrid framework
Peter Wang pengxwang at hotmail.com
Mon Feb 7 10:49:28 CST 2011
Thanks, Barry,
   I didn't  run with  with -ksp_monitor_true_residual -ksp_converged_reason.  My own code was built based on the petsc-current/src/ksp/ksp/examples/tutorials/ex2f.F.  Since the line of 248 which with KSPSetTolerances is commented out, it seems I didn't set the tolerance in my code.
  If I need to run with option -ksp_monitor_true_residual -ksp_converged_reason , I should add some lines like:
    call PetscOptionsHasName()
    call KSPGetConvergedReason()
 Am I right?
In order to make the problem clear, I just attached the discription of my problem. Thanks a lot for any help from you.
Following is the portion of the code with KSP solver.
      call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
      call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
      call KSPSolve(ksp,b,x,ierr)
      call KSPGetIterationNumber(ksp,its,ierr)
        if (myid .eq. 0) then
            if (norm .gt. 1.e-12) then
            write(6,100) norm,its
            else
            write(6,110) its
            endif
        endif
    100 format('Norm of error ',e10.4,' iterations ',i5)
    110 format('Norm of error < 1.e-12,iterations ',i5)
> From: bsmith at mcs.anl.gov
> Date: Sun, 6 Feb 2011 21:30:56 -0600
> To: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] questions about the multigrid framework
> On Feb 6, 2011, at 5:00 PM, Peter Wang wrote:
> > Hello, I have some concerns about the multigrid framework in PETSc.
> > We are trying to solve a two dimensional problem with a large variety in length scales. The length of computational domain is in order of 1e3 m, and the width is in 1 m, nevertheless, there is a tiny object with 1e-3 m in a corner of the domain.
> > As a first thinking, we tried to solve the problem with a larger number of uniform or non-uniform grids. However, the error of the numerical solution increases when the number of the grid is too large. In order to test the effect of the grid size on the solution, a domain with regular scale of 1m by 1m was tried to solve. It is found that the extreme small grid size might lead to large variation to the exact solution. For example, the exact solution is a linear distribution in the domain. The numerical solution is linear as similar as the exact solution when the grid number is nx=1000 by ny=1000. However, if the grid number is nx=10000 by ny=10000, the numerical solution varies to nonlinear distribution which boundary is the only same as the exact solution.
> Stop right here. 99.9% of the time what you describe should not happen, with a finer grid your solution (for a problem with a known solution for example) will be more accurate and won't suddenly get less accurate with a finer mesh.
> Are you running with -ksp_monitor_true_residual -ksp_converged_reason to make sure that it is converging? and using a smaller -ksp_rtol <tol> for more grid points. For example with 10,000 grid points in each direction and no better idea of what the discretization error is I would use a tol of 1.e-12
> Barry
> We'll deal with the multigrid questions after we've resolved the more basic issues.
> > The solver I used is a KSP solver in PETSc, which is set by calling :
> > KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr). Whether this solver is not suitable to the system with small size grid? Or, whether the problem crossing 6 orders of length scale is solvable with only one level grid system when the memory is enough for large matrix? Since there is less coding work for one level grid size, it would be easy to implement the solver.
> > I did some research work on the website and found the slides by Barry on
> > http://www.mcs.anl.gov/petsc/petsc-2/documentation/tutorials/Columbia04/DDandMultigrid.pdf
> > It seems that the multigrid framework in PETSc is a possible approach to our problem. We are thinking to turn to the multigrid framework in PETSc to solve the problem. However, before we dig into it, there are some issues confusing us. It would be great if we can get any suggestion from you:
> > 1 Whether the multigrid framework can handle the problem with a large variety in length scales (up to 6 orders)? Is DMMG is the best tool for our problem?
> > 2 The coefficient matrix A and the right hand side vector b were created for the finite difference scheme of the domain and solved by KSP solver (callKSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)). Is it easy to immigrate the created Matrix A and Vector b to the multigrid framework?
> > 3 How many levels of the subgrid are needed to obtain a solution close enough to the exact solution for a problem with 6 orders in length scale?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110207/19f08dbb/attachment-0001.htm>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110207/19f08dbb/attachment-0001.pdf>
