[petsc-users] Configuring petsc with MPI on ubuntu quad-core
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Wed Feb  2 18:17:45 CST 2011
Barry,
Please find attached the patch for the minor change to control the
number of elements from command line for snes/ex20.c. I know that this
can be achieved with -grid_x etc from command_line but thought this
just made the typing for the refinement process a little easier. I
apologize if there was any confusion.
Also, find attached the full log summaries for -np=1 and -np=2. Thanks.
Vijay
On Wed, Feb 2, 2011 at 6:06 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  We need all the information from -log_summary to see what is going on.
>  Not sure what -grid 20 means but don't expect any good parallel performance with less than at least 10,000 unknowns per process.
>   Barry
> On Feb 2, 2011, at 5:38 PM, Vijay S. Mahadevan wrote:
>> Here's the performance statistic on 1 and 2 processor runs.
>> /usr/lib/petsc/linux-gnu-cxx-opt/bin/mpiexec -n 1 ./ex20 -grid 20 -log_summary
>>                         Max       Max/Min        Avg      Total
>> Time (sec):           8.452e+00      1.00000   8.452e+00
>> Objects:              1.470e+02      1.00000   1.470e+02
>> Flops:                5.045e+09      1.00000   5.045e+09  5.045e+09
>> Flops/sec:            5.969e+08      1.00000   5.969e+08  5.969e+08
>> MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
>> MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
>> MPI Reductions:       4.440e+02      1.00000
>> /usr/lib/petsc/linux-gnu-cxx-opt/bin/mpiexec -n 2 ./ex20 -grid 20 -log_summary
>> Time (sec):           7.851e+00      1.00000   7.851e+00
>> Objects:              2.000e+02      1.00000   2.000e+02
>> Flops:                4.670e+09      1.00580   4.657e+09  9.313e+09
>> Flops/sec:            5.948e+08      1.00580   5.931e+08  1.186e+09
>> MPI Messages:         7.965e+02      1.00000   7.965e+02  1.593e+03
>> MPI Message Lengths:  1.412e+07      1.00000   1.773e+04  2.824e+07
>> MPI Reductions:       1.046e+03      1.00000
>> I am not entirely sure if I can make sense out of that statistic but
>> if there is something more you need, please feel free to let me know.
>> Vijay
>> On Wed, Feb 2, 2011 at 5:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Wed, Feb 2, 2011 at 5:04 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
>>> wrote:
>>>> Matt,
>>>> The -with-debugging=1 option is certainly not meant for performance
>>>> studies but I didn't expect it to yield the same cpu time as a single
>>>> processor for snes/ex20 i.e., my runs with 1 and 2 processors take
>>>> approximately the same amount of time for computation of solution. But
>>>> I am currently configuring without debugging symbols and shall let you
>>>> know what that yields.
>>>> On a similar note, is there something extra that needs to be done to
>>>> make use of multi-core machines while using MPI ? I am not sure if
>>>> this is even related to PETSc but could be an MPI configuration option
>>>> that maybe either I or the configure process is missing. All ideas are
>>>> much appreciated.
>>> Sparse MatVec (MatMult) is a memory bandwidth limited operation. On most
>>> cheap multicore machines, there is a single memory bus, and thus using more
>>> cores gains you very little extra performance. I still suspect you are not
>>> actually
>>> running in parallel, because you usually see a small speedup. That is why I
>>> suggested looking at -log_summary since it tells you how many processes were
>>> run and breaks down the time.
>>>    Matt
>>>> Vijay
>>>> On Wed, Feb 2, 2011 at 4:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> On Wed, Feb 2, 2011 at 4:46 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
>>>>> wrote:
>>>>>> Hi,
>>>>>> I am trying to configure my petsc install with an MPI installation to
>>>>>> make use of a dual quad-core desktop system running Ubuntu. But
>>>>>> eventhough the configure/make process went through without problems,
>>>>>> the scalability of the programs don't seem to reflect what I expected.
>>>>>> My configure options are
>>>>>> --download-f-blas-lapack=1 --with-mpi-dir=/usr/lib/ --download-mpich=1
>>>>>> --with-mpi-shared=0 --with-shared=0 --COPTFLAGS=-g
>>>>>> --download-parmetis=1 --download-superlu_dist=1 --download-hypre=1
>>>>>> --download-blacs=1 --download-scalapack=1 --with-clanguage=C++
>>>>>> --download-plapack=1 --download-mumps=1 --download-umfpack=yes
>>>>>> --with-debugging=1 --with-errorchecking=yes
>>>>> 1) For performance studies, make a build using --with-debugging=0
>>>>> 2) Look at -log_summary for a breakdown of performance
>>>>>    Matt
>>>>>> Is there something else that needs to be done as part of the configure
>>>>>> process to enable a decent scaling ? I am only comparing programs with
>>>>>> mpiexec (-n 1) and (-n 2) but they seem to be taking approximately the
>>>>>> same time as noted from -log_summary. If it helps, I've been testing
>>>>>> with snes/examples/tutorials/ex20.c for all purposes with a custom
>>>>>> -grid parameter from command-line to control the number of unknowns.
>>>>>> If there is something you've witnessed before in this configuration or
>>>>>> if you need anything else to analyze the problem, do let me know.
>>>>>> Thanks,
>>>>>> Vijay
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments
>>>>> is infinitely more interesting than any results to which their
>>>>> experiments
>>>>> lead.
>>>>> -- Norbert Wiener
>>> What most experimenters take for granted before they begin their experiments
>>> is infinitely more interesting than any results to which their experiments
>>> lead.
>>> -- Norbert Wiener
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110202/b1b8c55d/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110202/b1b8c55d/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110202/b1b8c55d/attachment-0003.obj>
