[petsc-users] KspTrueResidualNorm
Ataollah Mesgarnejad
amesga1 at tigers.lsu.edu
Tue Feb 1 15:27:03 CST 2011
I compile it with openmpi and it runs on 5 cores. And thats all the error
message from PETSC. the compelete output looks like this:
[3]PETSC ERROR: MatHYPRE_IJMatrixCreate() line 76 in src/dm/da/utils/mhyp.c
[3]PETSC ERROR: PCSetUp_HYPRE() line 112 in src/ksp/pc/impls/hypre/hypre.c
[3]PETSC ERROR: PCSetUp() line 795 in src/ksp/pc/interface/precon.c
[3]PETSC ERROR: KSPSetUp() line 237 in src/ksp/ksp/interface/itfunc.c
[3]PETSC ERROR: KSPSolve() line 353 in src/ksp/ksp/interface/itfunc.c
[3]PETSC ERROR: UStep() line 511 in PFMAT-FD.cpp
[4]PETSC ERROR: MatHYPRE_IJMatrixCreate() line 76 in src/dm/da/utils/mhyp.c
[4]PETSC ERROR: PCSetUp_HYPRE() line 112 in src/ksp/pc/impls/hypre/hypre.c
[4]PETSC ERROR: PCSetUp() line 795 in src/ksp/pc/interface/precon.c
[4]PETSC ERROR: KSPSetUp() line 237 in src/ksp/ksp/interface/itfunc.c
[3]PETSC ERROR: main() line 95 in PFMAT-main.cpp
[4]PETSC ERROR: KSPSolve() line 353 in src/ksp/ksp/interface/itfunc.c
[4]PETSC ERROR: UStep() line 511 in PFMAT-FD.cpp
[4]PETSC ERROR: main() line 95 in PFMAT-main.cpp
MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 3 with PID 3845 on
node me-1203svr3.lsu.edu exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
Best,
Ata
On Tue, Feb 1, 2011 at 2:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Right preconditioner shouldn't matter to the preconditioner at all. What
> is the complete error message. Does it run on one process?
> Barry
> On Feb 1, 2011, at 2:32 PM, Ataollah Mesgarnejad wrote:
> > Barry,
> > I did as you said and now I receive these errors once I try to run the
> program:
> > Does right preconditiong work with HYPRE?
> > Best,
> > Ata
> > On Tue, Feb 1, 2011 at 2:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > The simplest thing is to simply run with -ksp_monitor_true_residual and
> see how the convergence is going in the true residual norm also.
> > You can also switch to right preconditioning with gmres and then the
> residual used by gmres is the true residual norm. Use
> -ksp_preconditioner_side right -ksp_norm_type unpreconditioned
> > Barry
> > On Feb 1, 2011, at 2:14 PM, Ataollah Mesgarnejad wrote:
> > > Dear all,
> > > I'm using Ksp gmres with boomeramg preconditioning and I suspect that
> even though it converges in preconditioned norm it doesn't converge in true
> norm, but as I understand KSPSetNormType gmres does not support true
> residual norm? Is that correct and If it is, is there any other way to
> monitor the true norm? Do I need to Introduce my own convergence test?
> > > Best,
> > > A. Mesgarnejad
> > A. Mesgarnejad
> > PhD Student, Research Assistant
> > Mechanical Engineering Department
> > Louisiana State University
> > 2203 Patrick F. Taylor Hall
> > Baton Rouge, La 70803
A. Mesgarnejad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110201/19495f57/attachment.htm>
