[petsc-users] KspTrueResidualNorm
Ataollah Mesgarnejad
amesga1 at tigers.lsu.edu
Tue Feb 1 14:35:38 CST 2011
Sorry for too many replies but it worked with -Ksp_monitor !!! I reported
the same kind of problem before too.
Best,
Ata
On Tue, Feb 1, 2011 at 2:32 PM, Ataollah Mesgarnejad <amesga1 at tigers.lsu.edu
> wrote:
> Barry,
> I did as you said and now I receive these errors once I try to run the
> program:
> [3]PETSC ERROR: MatHYPRE_IJMatrixCreate() line 76 in src/dm/da/utils/mhyp.c
> [3]PETSC ERROR: PCSetUp_HYPRE() line 112 in src/ksp/pc/impls/hypre/hypre.c
> [3]PETSC ERROR: PCSetUp() line 795 in src/ksp/pc/interface/precon.c
> [3]PETSC ERROR: KSPSetUp() line 237 in src/ksp/ksp/interface/itfunc.c
> [3]PETSC ERROR: KSPSolve() line 353 in src/ksp/ksp/interface/itfunc.c
> [3]PETSC ERROR: UStep() line 511 in PFMAT-FD.cpp
> [4]PETSC ERROR: MatHYPRE_IJMatrixCreate() line 76 in src/dm/da/utils/mhyp.c
> [4]PETSC ERROR: PCSetUp_HYPRE() line 112 in src/ksp/pc/impls/hypre/hypre.c
> [4]PETSC ERROR: PCSetUp() line 795 in src/ksp/pc/interface/precon.c
> [4]PETSC ERROR: KSPSetUp() line 237 in src/ksp/ksp/interface/itfunc.c
> [3]PETSC ERROR: main() line 95 in PFMAT-main.cpp
> [4]PETSC ERROR: KSPSolve() line 353 in src/ksp/ksp/interface/itfunc.c
> [4]PETSC ERROR: UStep() line 511 in PFMAT-FD.cpp
> [4]PETSC ERROR: main() line 95 in PFMAT-main.cpp
> Does right preconditiong work with *HYPRE*?
> Best,
> Ata
> On Tue, Feb 1, 2011 at 2:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> The simplest thing is to simply run with -ksp_monitor_true_residual and
>> see how the convergence is going in the true residual norm also.
>> You can also switch to right preconditioning with gmres and then the
>> residual used by gmres is the true residual norm. Use
>> -ksp_preconditioner_side right -ksp_norm_type unpreconditioned
>> Barry
>> On Feb 1, 2011, at 2:14 PM, Ataollah Mesgarnejad wrote:
>> > Dear all,
>> > I'm using Ksp gmres with boomeramg preconditioning and I suspect that
>> even though it converges in preconditioned norm it doesn't converge in true
>> norm, but as I understand KSPSetNormType gmres does not support true
>> residual norm? Is that correct and If it is, is there any other way to
>> monitor the true norm? Do I need to Introduce my own convergence test?
>> > Best,
>> > A. Mesgarnejad
> A. Mesgarnejad
> PhD Student, Research Assistant
> Mechanical Engineering Department
> Louisiana State University
> 2203 Patrick F. Taylor Hall
> Baton Rouge, La 70803
A. Mesgarnejad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110201/dee9f7d8/attachment-0003.htm>
