[petsc-users] invalid object classid 0 between PETSc and SLEPc
Jose E. Roman
jroman at dsic.upv.es
Wed Dec 28 04:02:05 CST 2011
I will forward this to the MacPorts maintainer.
Jose
El 28/12/2011, a las 05:16, Geoffrey Irving escribió:
> Hello,
> I've installed PETSc 3.2 and SLEPc 3.2 on Mac OS 10.7 through MacPorts
> 2.0.3. PETSc works fine by itself, but SLEPc fails on the initial
> EPSCreate call. The error follows.
> This is presumably a MacPorts misconfiguration issue, but thought I'd
> check here first to see if anyone has seen this before in a similar
> situation. Only static libraries exist, so as far as I know the
> suggested explanation doesn't apply. The conf directory is at
> http://naml.us/~irving/random/petsc-conf.tar.gz if it helps.
> Thanks,
> Geoffrey
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Invalid object classid 0
> This often happens if you compile with PETSC_USE_DYNAMIC_LIBRARIES,
> but link with static libraries.!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
> 13:45:54 CDT 2011
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: Unknown Name on a darwin named tile.local by irving
> Tue Dec 27 19:07:59 2011
> [0]PETSC ERROR: Libraries linked from
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_math_petsc/petsc/work/destroot/opt/local/lib/petsc/lib
> [0]PETSC ERROR: Configure run at Mon Nov 21 14:00:28 2011
> [0]PETSC ERROR: Configure options --prefix=/opt/local --with-python
> --with-debugging=0 --with-c-support=1 --with-c++-support=1
> --with-pic=fPIC --with-shared-libraries=0 --with-mpi=1
> --PETSC_ARCH=darwin
> --prefix=/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_math_petsc/petsc/work/destroot/opt/local/lib/petsc
> --with-cc=/opt/local/bin/openmpicc
> --with-cxx=/opt/local/bin/openmpicxx
> --with-mpiexec=/opt/local/bin/openmpiexec
> --with-fc=/opt/local/bin/openmpif90 --LIBS=-lstdc++
> [0]PETSC ERROR:
> [0]PETSC ERROR: PetscClassRegLogGetClass() line 282 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_math_petsc/petsc/work/petsc-3.2-p5/src/sys/plog/utils/classLog.c
> [0]PETSC ERROR: PetscLogObjCreateDefault() line 310 in
> [0]PETSC ERROR: EPSCreate() line 436 in src/eps/interface/basic.c
> [0]PETSC ERROR: !
> [0]PETSC ERROR:
> 13:45:54 CDT 2011
> [0]PETSC ERROR:
> --PETSC_ARCH=darwin
> [0]PETSC ERROR:
> [0]PETSC ERROR: sparse_symmetric_spectrum() line 55 in petsc/slepc.cpp
