[petsc-users] PetscMallocSpace() and PetscGetResidentSetSize() are absent
Matthew Knepley
knepley at gmail.com
Mon Dec 26 09:37:50 CST 2011
On Mon, Dec 26, 2011 at 9:09 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> >From the FAQ:
> "Use the commands PetscMallocSpace() and PetscGetResidentSetSize() to
> monitor memory allocated and total memory used as the code
> progresses."
You want
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscMemoryGetCurrentUsage.html
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscMallocGetCurrentUsage.html
I will fix the FAQ
Matt
> These two functions, however, are missing entries in
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/singleindex.html
> Where is their documentation?
> Thanks
> Dominik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111226/73db9697/attachment.htm>
