[petsc-users] KSP diverging
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Fri Dec 23 19:14:35 CST 2011
Thank you guys,
What happens right now when I use GMRES is that it reaches the maximum
number of iterations I set, i.e. 1000 (which should not). I have set the
restart to 20 (and then increased it to 1000) but no luck. It never
converges.
On Fri, Dec 23, 2011 at 7:23 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Dec 23, 2011 at 07:43, Matthew Knepley <knepley at gmail.com> wrote:
>> Even if you lose orthogonality, it will just stagnate since you always
>> have the solution
>> from the first few vectors. Likewise, I do not see how you can get an
>> diverging sequence
>> from restarting since you always have the last residual, you just
>> stagnate.
> The true residual can grow even though the estimate of the preconditioned
> residual decreases monotonically. When you restart, you re-evaluate the
> actual residual, which might be much larger.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111223/cfae4546/attachment.htm>
