[petsc-users] -ksp_diagonal_scale
Jed Brown
jedbrown at mcs.anl.gov
Fri Dec 23 13:21:17 CST 2011
On Thu, Dec 22, 2011 at 20:50, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
> 1) As mentioned on the web when we use
> *-ksp_diagonal_scale_fix: *scale the matrix back AFTER the solve
> with -ksp_diagonal_scale does it also scale back the RHS vector
> associated with the KSP solver?
yes
> 2) Also, as mentioned on the web for -ksp_diagonal_scale
> "Tells KSP<http://www.mcs.anl.gov/petsc/petsc-3.1/docs/manualpages/KSP/KSP.html#KSP> to
> symmetrically diagonally scale the system before solving. "
> When I used this option to solve for the Pressure (Poisson equation with
> Neumann B.C., descritized via structured fisytenite-difference method), the
> number of iterations for convergence was trippled, e.g. without this
> option, it converges in 18 iteration, but with this option it goes up to
> 50-60 iterations.
> (GMRES + BoomerAMG as the preconditioner).
> Is this something you would expect?
It's perhaps slightly surprising that it's that much worse, but there is
nothing saying that the diagonal scaled matrix will be better. Most
preconditioners correct the diagonal scaling.
> 3) How could the linear system resulting from the Poisson equation for
> pressure (incompressible flow) can be more diagonally scaled? To elaborate
> more, for the uniform grid case and let's say a second order central scheme
> finite difference discretization, the sum of the off-diagonal coefficients
> are equal to the diagonal coefficient.
You probably don't have a reason to use diagonal scaling.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111223/fbe3dc46/attachment.htm>
