[petsc-users] -ksp_diagonal_scale
Alexander Grayver
agrayver at gfz-potsdam.de
Fri Dec 23 04:11:04 CST 2011
Sorry for small offtopic.
I would also be interested more to know how it scales system? I mean
what is idea behind this scaling.
Alexander
On 23.12.2011 03:50, Mohamad M. Nasr-Azadani wrote:
> Hi guys,
> Three questions:
> 1) As mentioned on the web when we use
> *-ksp_diagonal_scale_fix: *scale the matrix back AFTER the solve
> with -ksp_diagonal_scale does it also scale back the RHS vector
> associated with the KSP solver?
> 2) Also, as mentioned on the web for -ksp_diagonal_scale
> "Tells KSP
> <http://www.mcs.anl.gov/petsc/petsc-3.1/docs/manualpages/KSP/KSP.html#KSP> to
> symmetrically diagonally scale the system before solving. "
> When I used this option to solve for the Pressure (Poisson equation
> with Neumann B.C., descritized via structured fisytenite-difference
> method), the number of iterations for convergence was trippled, e.g.
> without this option, it converges in 18 iteration, but with this
> option it goes up to 50-60 iterations.
> (GMRES + BoomerAMG as the preconditioner).
> Is this something you would expect?
> 3) How could the linear system resulting from the Poisson equation for
> pressure (incompressible flow) can be more diagonally scaled? To
> elaborate more, for the uniform grid case and let's say a second order
> central scheme finite difference discretization, the sum of the
> off-diagonal coefficients are equal to the diagonal coefficient.
> Thanks,
> Best,
> Mohamad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111223/efb7d4c6/attachment.htm>
