[petsc-users] KSP diverging
Thu Dec 22 19:31:04 CST 2011
On Thu, Dec 22, 2011 at 19:20, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
> Any hints on what is happening here or how I could narrow it down?
I would start by following the general advice in the FAQ
http://www.mcs.anl.gov/petsc/documentation/faq.html#kspdiverged
> I know that we had an early discussion on the convergnce for the
> incompressible CFD problems and boomerAMG preconditioning,
That was about solving the coupled system. That shouldn't be an issue for
the Poisson problem.
> but it seems that for this case, that is the only one that does not blow
> up for most of the time integration I have.
Since this problem only occurs after long time integration, you might
consider writing out the model state when you see divergence so that you
can experiment with alternative methods quickly.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111222/ea87dbc8/attachment.htm>
