[petsc-users] boomerAmg scalability
Matthew Knepley
knepley at gmail.com
Wed Dec 21 18:55:30 CST 2011
On Wed, Dec 21, 2011 at 6:40 PM, Mohamad M. Nasr-Azadani
<mmnasr at gmail.com>wrote:
> Thank you Jed for the detailed explanation. To tell you the truth, that
> was a bit overwhelming/scary for an engineer like me-that I have to be
> supercareful when using those solvers and preconditioners- :D
> For my case though, I decided to fix the pressure at one node in the
> domain so I won't end up with a null-space case of the Pressure equation.
> I assume that way, I would not have to worry about the nullspace problems
> and the convergence issues you pointed out, right?
Nope. You have removed the null space from the operator on the full domain,
but not the subdomains that Jed
was talking about. I think this method only complicates things since now
one subdomain looks weird, and the
behavior of the coarse operator in unpredictable since i don't know where
this point is.
Matt
> Best,
> Mohamad
> On Mon, Dec 19, 2011 at 9:09 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Mon, Dec 19, 2011 at 20:57, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> So please tell use how we SHOULD use AMG with those "indefinite problem
>>> produced by most discretizations of incompressible flow" dear teacher :-)
>> If only there was a nice complete answer...
>> We can do block preconditioners advocated by Elman and others. These are
>> the most flexible and the simplest for code reuse. For low Reynolds number,
>> they can also have optimal complexity, although the constants are usually
>> not the best. Most variants are well-supported by PCFieldSplit (e.g. with
>> PCLSC), but some need the user to provide auxiliary operators (e.g. the
>> "pressure convection-diffusion" variant). We could improve support for
>> these cases, but it's a delicate balance and I don't know any way to avoid
>> asking the user to understand a reasonable amount about the method and
>> usually to provide auxiliary information.
>> We can do coupled multigrid with fieldsplit or "distributed relaxation"
>> as a smoother. These can often be made more robust, but they tend to be
>> more intrusive to implement. These are not usually purely algebraic due to
>> inf-sup issues when coarsening the dual variables (pressure), though Mark
>> Adams' work on this for contact mechanics could be used to coarsen pressure
>> algebraically. I would like to experiment with this in PCGAMG.
>> We can do coupled multigrid with compatible Vanka-type smoothers. Whether
>> these are algorithmically effective and/or efficient is quite dependent on
>> the discretization. These methods are also usually geometric, though it's
>> possible to algebraically define a Vanka-smoother (though not necessarily
>> efficient). This is straightforward for MAC finite differences on
>> structured grids. For continuous finite elements, the "rotated Q1"
>> Rannacher-Turek elements are most attractive for these smoothers, but
>> Rannacher-Turek elements do not satisfy a discrete Korn's inequality, so
>> they are unusable for many problems. Some variants of DG for incompressible
>> flow seem to be the most interesting for this approach in general domains.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111221/c0cc6f04/attachment.htm>
